NULL filter?
whoareyou
My AV System
Benchmark AHB2
ATI AT525NC
JRiver
Exasound E38
Psb synchrony one
PSB synchrony one C
Revel m105
I'd like to create filter that only does channel mapping (cfg + wav). in Jriver i.e. what I refer to as NULL filter.
It seems that deleting the wav files for the filter accomplishes this,
Does this make sense?
juicehifi
Audiolense
No. A filter that lets everything true has one coefficient with the value 1.0
Omid
I think JRiver allows you to do that directly.
In DSP Studio, select Parametric equalizer, then add "mix Channel". You can choose a source channel, a destination channel and whether you want to swap one for he other, copy, move, add, substract. So hopefully you can create whatever map you want.
whoareyou
My AV System
Benchmark AHB2
ATI AT525NC
JRiver
Exasound E38
Psb synchrony one
PSB synchrony one C
Revel m105
Yes, that is true, but the purpose of the filter is to use with hang loose convolver to make comparison between no filter and AL filters.
Omid
Ahh!
This is going to require a bit of nerding out, but it can be done. I haven't tested it thoroughly but give it a try.
So I created a wav file that's an impulse of 1 and has a tap length of 131072. It's a single channel wave file. I Called it null.wav
the cfg file looks (in my example) looks like this:
44100 2 2 0
0 0
0 0
null.wav
0
0.0
1.0
null.wav
0
1.0
0.0
It selects null.wav channel 0 (the only channel in this identity wav file), convolves channel 0 (left stereo signal) and outputs it to channel 1 (right stereo signal).
Then, It selects null.wav channel 0 (the only channel in this identity wav file), convolves channel 1 (right stereo signal) and outputs it to channel 0 (left stereo signal).
So it swaps right for Left.
If you want to use it in your own case scenario, just replace in your cfg file :
*.wav
x
with
null.wav
0
It should give you a null filter with the same channel assignment as your filter.
Omid
If my explanation was not clear, post your zip file here, I'll modify it for you.
Ofer
My AV System
miniDSP 4x10hd
Emotiva XPR200 midrange amp
Crest audio 2001A bass amp
Rotel RA930ax twitter amp
Sony Bravia android TV
miniDSP 4*10HD
Andromeda MkII
Sony bravia 65XF9005
Deezer HiFi
Marantz original 5E CD
Are you using passive or active system? If the latter you can build a crossover only filter with no frequency or time domain correction and compare that.
whoareyou
My AV System
Benchmark AHB2
ATI AT525NC
JRiver
Exasound E38
Psb synchrony one
PSB synchrony one C
Revel m105
Thanks very much for this. Now that I've had chance to think about this some more, I don't think this makes sense for anything but 2 channel system. In my case I have 5.1 system with parallel subs (on the .1 sub channel) and each speaker also has crossover. So, just passing everything through seems to just not work.
whoareyou
My AV System
Benchmark AHB2
ATI AT525NC
JRiver
Exasound E38
Psb synchrony one
PSB synchrony one C
Revel m105
It's passive system.
Great suggestion!
Omid
Much better suggestion!!!
