(September 23, 2026) Epson is making a pretty significant move with its Home Cinema lineup for 2026, bringing laser illumination and its latest 4K display technology into price ranges once largely occupied by lamp-based machines. Three new models are joining the family: the Home Cinema LS5000, LS6000, and LS7500, with pricing stretching from $1,999 to $2,699. All three sit below the existing LS11000 and are aimed squarely at enthusiasts who want a large-screen 4K HDR experience without having to climb into Epson's more expensive dedicated theater offerings.
There’s quite a bit of shared DNA across the three models. Each uses Epson’s 3-chip 3LCD architecture with a true laser diode array and the company’s 4K Display Technology, which uses advanced 4-way pixel shifting to put a full 8.29 million pixels on screen. HDR10 and HLG High Dynamic Range formats are supported with full 10-bit color processing, along with Epson Automatic HDR Scene Correction, while dual HDMI connections support refresh rates up to 120Hz. Epson also rates the laser light source for up to 20,000 hours in Normal Mode, which removes one of the more obvious ownership headaches associated with lamp-based projection.
The LS5000 serves as the entry point, but doesn’t read like a stripped-down model. Epson rates it at 2,500 lumens for both color and white brightness, with an 800,000:1 dynamic contrast ratio and support for images from 40" to 300". Its Epson Cinema Lens carries a 1.32 to 2.15 throw ratio with manual optical zoom, focus, and lens shift (±59% vertical, ±21% horizontal). Gaming support includes a 120Hz refresh rate, Auto Low Latency Mode, and input lag below 20ms, giving the LS5000 legitimate crossover appeal for movies, sports, and console gaming.
Moving up to the LS6000 brings a fairly substantial jump in light output, with Epson rating it at 3,400 lumens for both color and white brightness. Dynamic contrast remains at 800,000:1, while the lens, placement flexibility, gaming features, and core video architecture closely mirror the LS5000. For rooms where some ambient light is unavoidable, or where a larger screen simply needs more brightness, that extra 900 lumens makes the LS6000 the sweet spot of the group. Like the LS5000, it supports screen sizes up to 300", Bluetooth audio for private listening, HDMI 2.1 connectivity, and a front-exiting airflow design that's intended to make placement easier.
Then there’s the LS7500, which is easily the most interesting new addition. Rated at 3,500 lumens with a 1,000,000:1 dynamic contrast ratio, it swaps the standard Cinema Lens for a new short-throw version with a 1.0 to 1.31 throw ratio. Epson says that allows the projector to sit roughly three feet closer to a screen than conventional models, with a 120" image requiring a mere 8.8 feet of throw distance. That radically opens up installation possibilities in rooms where projector depth, meaning a projector's maximum allowable distance from a screen, is a limiting factor, while still preserving manual lens shift and support for screen sizes from 40" to 300".
Installation flexibility is clearly a major part of the story across all three models, as is cost. Epson is supporting everything from traditional 16:9 HDTV content to wider 21:9 presentations, with compact chassis designs, front-exiting airflow, wide-range manual lens shift, and Bluetooth 6.0 for sending two-channel audio from HDMI sources directly to wireless headphones. The LS7500 adds a few more integration-friendly touches, including RS-232 control and a 12V trigger output.
All three models slot below the LS11000, which remains at the top of Epson’s Home Cinema range. Landing at $4,499, the LS11000 boasts a Precision Lens, motorized lens shift and memory, Epson's RX Picture Processor, HDR10+ support, and a higher 1,200,000:1 dynamic contrast ratio.
The Home Cinema LS5000 carries a $1,999.99 MSRP, the LS6000 lands at $2,199.99, and the LS7500 tops the new group at $2,699.99. Epson says all three will be available in late September through its online store and select retailers. For buyers who have been waiting for laser projection to move into more approachable price territory, September just became considerably more interesting.
Epson LS6000
Epson LS5000
Related Reading:
- NEWS: Marantz MCR 60n Might Be the Coolest All-in-One Hi-Fi System We’ve Seen in Years
- NEWS: Dirac Turns 25 as Its Room Correction Reach Keeps Expanding
- NEWS: Inside the ProSource 1010 Experience Center: An Exclusive AV NIRVANA Tour
- NEWS: World Premiere Unveiling! Ascendo's New Panoramic Surface On-Wall Appears at CEDIA 2026
- NEWS: madAssist Takes madVR Envy Support Into Wild New Territory
- NEWS: DreamWall’s Monarch MicroLED Display Unfolds Like a Butterfly, See It at CEDIA 2026
- NEWS: Kaleidescape Marks 25 Years with a Massive Presence at CEDIA Expo 2026
