Trace Arithmetic solution sought
bobkatz
Main monitor controller: Cranesong Avocet (8 ch)
Atsah 500
Oppo
Dynaudio Evidence M5P
Lipinski L-707
Lipinski L-505
JL Fathom F-112 (2)
Hi, John. I'm trying to show the DIFFERENCE in amplitude between using some traps and no traps in my room. I've tried all kinds of trace arithmetic and different displays (including V/V) to no avail. What I'd like to see is, for example, if with the trap at 100 Hz the amplitude is 78 dB SPL but without the trap the amplitude is 80 dB SPL, the resultant graph should show a 2 dB difference. If there isno difference the result should be 0 dB.
That's best done using A/B with magnitude-only responses. To generate magnitude-only responses select only the measurement that is to be converted to magnitude-only (no other measurements selected) and click Average the responses, that will generate a new trace whose name begins "Magn". Repeat that for the other measurement (again making sure it is the only measurement selected). Use A/B on the two magn results.
thothsong
Just to note, the result can look rather different if you smooth the Magn traces before computing A/B, versus computing A/B and then smoothing that.
sam_adams
You might wan to take a look at this question I had for @John Mulcahy a while back. Seems to be the same thing that you are trying to accomplish.
bobkatz
Atsah 500
Oppo
Lipinski L-707
Lipinski L-505
JL Fathom F-112 (2)
Thanks for that advice!
Lol... The Cranesong Avocet might be the giveaway...
pklose
Could be a clue. But I checked other posts. Urls with pics and stuff lead to digido.com. Which is Bob‘s facility. Awesome! Bob‘s book on mastering was a source for my bachelor thesis - some 15 years ago.
TNT
Would be really nice to have that as a ready made "short cut" in that very menu.. the arithmetic one :)
TNT
Is it possible to do the same but for phase?
PS aiming for a mic calibration / compensation file... maybe there is a better way :-)
Not sure what you mean by that, if you want a result with magnitude and phase use A/B.
TNT
Coming back to understanding the difference between two measurements.... would it be possible to have a function that makes a as complete diff report as possible by pointing to measure A and measure B and hit "Diff Rep"... as a graphics and perhaps text...
UC: Everything set up, make sweep, make one small change to DUT, new measurement - understand difference.... :-)
