Please help w/equalizer hook up to AV receiver...
TroyHR
I,ve been all over youtube and seen many diagrams and still cannot get phono to work with my BSR equalizer and Sony STR DE 885 reciever...!
Phono in ,
tape in/out from reciever to
tape out in at equalizer...
reciever switched to tape I and I get nothing...sound thru phono but no EQ...!
What am I doing wrong..? I would pay nearly anything at this point
This may be lengthy, Thankyou for reading.
Wayne A. Pflughaupt
Corpus Christi, TX
Canton Karat 920
Canton Karat 920
Canton Plus D
Hsu ULS-15 MKII
Stock Yamaha Remote
Roku Express
Unless the receiver has a button labeled “Tape Monitor,” you won’t be able to use the equalizer as it was originally intended. The only way to use outboard equalizers these days is between the source component, or between the receiver and an outboard amplifier.
Wayne A. Pflughaupt
Tony V.
Edmonton, AB, Canada
Onkyo TX RZ920
Samson Servo 600
QSC MX1500
Panasonic 220
EV Sentry 500
EV Sentry 500
Mission 762
Mission 762
SVS PB13u
Panasonic AE 8000
Logitech 1100
Modern day receivers do not have the ability to do as you are requesting, Wayne is correct. The only way to eq the sound is to record the output of the turntable through the receiver on a PC apply eq using software and saving that file for playback.
TroyHR
Thanks guy's...I was afraid of that....
