PassionforSound
- Oct 5, 2020
- 2
Hi all, I'm REALLY hoping someone can help me with a weird issue so I can make a video to help folks with the DMP-A8. I'll try to summarise the situation briefly:
Here's what the FIRs straight from REW look like:
Here's what happens when I go out to rePhase, back into REW and then export the IR as a wav. The left channel is the rePhase/REW version (that looks like an impulse response displayed as dBFS) and the right is the original REW version before rePhase.
One final point to mention is that the same process that's not working for the DMP-A8 is working perfectly in Roon. Any suggestions of what I need to look at/do differently?
- Measure speakers using UMIC-1 (all good)
- Create appropriate filter settings in REW (all good)
- Export filter settings as impulse response and upload into DMP-A8 (all good)
...then things get weird (or I'm doing it wrong)... - Take the original filter settings into rePhase to produce a linear phase version of the filters (all good)
- Export 32-bit IEEE wav from rePhase for the L & R channels respectively (all good)
- Import the impulse responses back into REW and everything looks OK
- Export the new impulse responses as wav files for the DMP-A8, but the A8 DSP gets all screwy
