Newbie question - REW and Umik-1 problem
Simna
Hi
Trying to get REW to work with Umik-1 but get this message when uploading the calibration file:
"The cal file has a sens factor entry but the input is not recognized usb mic. The sens factor entry will not be used."
What does this mean and what am I to do?
sm52
I also had this message. If this is the very first connection to Umik, then you need to close REW and restart the computer. Let Umik remain connected. After reboot, run REW. There will be a message that Umik has been detected, should I use it? Agree. This time that message about sens factor should not appear. It worked for me like this. But it looks like something John can fix.
Simna
Hi sm52
Yes, it's the first time connecting the Umik-1.
OK, I'll try that.
Thank you very much!
