Feature Request: Simultaneous display of SPL Slow and Leq
BananaHanger
Hello all
I love the SPL logger function within REW and have found it to be very useful for smaller gigs where SMAART is not in the budget. One thing that I do miss however is the ability to see SPL Slow and Leq at the same time. In the SPL measurement functionality you can choose to see one or the other at a time, but as far as I can tell there is no way to see both at the same time.
Is it possible to add the ability to view both simultaneously? For example dba slow and Laeq 10 side by side.
What version are you running? The logger in the V5.40 beta version already does that. If you have the Pro upgrade you could also put the same signal on two input channels and show two SPL meters, each with your preferred measure (4 meters are possible with multi-input showing the first 4 channels of the selected input channel range).
when you say that it’s possible in the ligger are you just referring to the values being logged and the lines/data being displayed on the graph or something else? If you’re just referring to the graph then yes I’m aware of that :)
I’m specifically referring to having two meters/readouts simultaneously. If that’s a pro feature then that’s fair enough
