Feature request - doing measurements in AL with correction filters engaged - like Acourate features
2234rew
Hi @juicehifi
I know verifcation can be done with 3rd party software like REW.
But Acourate has a feature that allows everything, including verification measurements, to be all contained in Acourate itself. You can load the correction filters into the measurement sweeps.
Would you consider adding this kind of feature to Audiolense?
This would make Audiolense fully 'self contained' with no need for any other software really.
juicehifi
Audiolense
You can do what you ask if you apply the Al convolver and make a full range configuration in Audiolense. But IMO it is not a very good idea to do this.
If the measurement is valid, the simulation is very accurate. This has been demonstrated by several users over the years.
And if the measurement isn't valid, there is a high risk that the problem will repeat itself on a control measurement performed by the same program (Audiolense). If you really want to verify, it is better to measure with a different program.
