Convolver streaming with different input and output USB devices
clarus
Can the Convolver support streaming with a USB input and a different USB output device? i.e. a USB ADC and a separate USB DAC.
The convolver itself can not do that. It only accepts one audio device and there's no mechanism for synchronizing two devices.
You could try with Asio4All in the middle and see how it goes.VB AsioBridge is another candidate.
Does the input and output device clock need to be synchronized in order for streaming to work properly?
One of the devices will stream slightly faster than the other, so some mechanism is needed to keep the two streams 100% in sync with each other.
The windows mixer has the capacity to do this. VB Audio probably runs through the mixer.
Come to think of it, JRiver as a virtual sound card might work too. You can activate the wdm audio driver in JRiver. Then it will appear as a selectable speaker in Windows. You set it as default speakers and make it listen to the input of your ADC. And then, in jriver, you send the audio to the convolver.
Maybe Asio4All has some way of keeping the two streams in sync as well, but it runs underneath the windows mixer so it needs its own solution.
There's no way to tell for sure whether any of these will work without trying.
Hi @clarus @juicehifi Bernt has given me permission to post about HLConvolver as it can support streaming with a USB input and a different USB output device:
This example is using an ESI U24XL USB ADC line input to stream in an external CD player through convolution and out to a USB Topping E30 DAC.
No additional s/w required.
A free trial is available: https://accuratesound.ca/hang-loose-convolver-hlc/
Kind regards,
Mitch
