CableRated Expands Beyond HDMI Cables With New NitZero Screen Cleaning Kit
(November 23, 2026) CableRated is expanding its product lineup by introducing NitZero, a foam-based screen-cleaning solution developed specifically for modern televisions and electronic displays. The company, founded by consumer electronics industry veterans Caleb Denison, Dipin Sehdev, and Alex Pasco, entered the AV market earlier this year with a line of affordable, high-bandwidth HDMI cables. We recently put its 1-meter and 3-meter cables through our HDMI Test Bench process, examining everything from physical construction and connector design to signal integrity and sustained 48 Gbps performance. Both passed our tests with flying colors. Now, CableRated is turning its attention to a familiar home theater challenge: keeping television screens clean without leaving behind streaks, smudges, or other unwanted residue.
NitZero was developed with today's increasingly complex screen surfaces in mind, particularly the matte and anti-reflective coatings found on many premium televisions. While distilled water and a microfiber cloth have traditionally been the go-to recommendation for cleaning displays, certain finishes can be surprisingly difficult to clean, especially when fingerprints and skin oils are involved. CableRated says it spent months evaluating cleaning formulas, application methods, and microfiber materials before arriving at NitZero's final design.
The company tested its solution on a range of displays, including OLED, QD-OLED, Mini-LED, and RGB Mini-LED televisions. According to Denison, the project grew out of a problem he regularly encounters while reviewing TVs. "Some of the new coatings for anti-glare or anti-reflective on today's TVs are incredibly difficult to clean," explains Denison, adding that he wanted a product he could confidently use on the displays passing through his studio.
Unlike conventional liquid screen cleaners, NitZero uses a foam dispenser intended to give users better control over how much solution is applied. Rather than spraying a display directly, a small amount of foam is applied to a microfiber cloth and gently wiped across the screen. The approach is designed to minimize excess moisture and reduce the possibility of liquid running down a vertical display or collecting near its edges. NitZero's formula is alcohol-free and ammonia-free, with a near-neutral pH and anti-static properties intended to help reduce dust accumulation. CableRated says the solution removes fingerprints, skin oils, and everyday smudges while minimizing visible streaks and residue. Although televisions were the primary focus during development, NitZero is also intended for computer monitors, laptops, tablets, smartphones, smartwatches, and other electronic displays.
The CableRated NitZero Screen Cleaning Kit is priced at $29.99 and includes a 150mL bottle of foam cleaner and oversized 12" x 12" microfiber cleaning cloths. It's available to order in the United States and Canada, with shipments currently scheduled for early December.
For more information and specific cleaning instructions, visit the CableRated NitZero product page.
Related Reading:
