ASCENDO's International Momentum Builds as Five Home Cinemas Win Six CEDIA Smart Home Awards
(November 23, 2026) ASCENDO Immersive Audio has spent the past several years establishing itself as a force in the world of high-performance home cinema, particularly when it comes to producing massive amounts of low-frequency energy. From its enormous infrasonic subwoofers to unconventional designs like THE28 SUB SQUARED, the German manufacturer has earned a reputation for pushing the limits of what's possible in a residential theater. But 2026 has revealed another side of ASCENDO's engineering ambitions. At CEDIA Expo, the company introduced its Panoramic Surface On-Wall, an entirely new kind of loudspeaker that uses a composite radiating surface to produce an exceptionally broad sound field, approaching 180 degrees of dispersion all the way up to 20kHz. The speaker was one of the more intriguing introductions at this year's show, demonstrating that ASCENDO's interests extend well beyond bass reproduction. Now, with 2026 entering its final stretch, the company has another reason to celebrate. Private cinemas equipped with ASCENDO loudspeakers and subwoofers captured six of the nine home cinema honors presented during the 2026 CEDIA Smart Home Awards, including the coveted Global Home Cinema award.
The six awards were spread across five private cinemas, representing projects from across the Asia-Pacific region and Europe. The most notable achievement belongs to "The Fourth Element," a private cinema in New Zealand designed and installed by the Australian integration firm The Digital Picture. Led by founder Scott Sauer, the project earned both Global Home Cinema and APAC Best Home Cinema Level I honors, along with separate awards for Excellence in Rack Building & Design and Excellence in Documentation. The theater itself is a complete reworking of an existing installation, featuring an 11.8.7 immersive audio system built around ASCENDO's THE HALO 10 PRO ACTIVE EXT CARDIOID loudspeakers and eight THE28 SUB SQUARED PRO PASSIVE subwoofers. Four of those subwoofers are positioned at the front of the room, with the remaining four at the rear, allowing Trinnov's WaveForming technology to manage low-frequency behavior throughout the seating area.
Sauer says the project placed particularly demanding requirements on the audio system, including high output capabilities, substantial low-frequency headroom, and low noise. Equally important was the ability to predict how the equipment would perform before installation. Accordingly, ASCENDO's published engineering data allowed The Digital Picture to design around specific performance targets rather than relying on assumptions about what the speakers and subwoofers might deliver once installed. That emphasis on measurable performance is a recurring theme among this year's winning projects and is one of the major reasons ASCENDO has gained traction with some of the industry's most accomplished cinema designers.
Another example comes from Cinema Buro, which won APAC Best Home Cinema Level II for a project called "It's About Time..." This installation uses ASCENDO THE BLACK SWAN loudspeakers across the front soundstage, 24 PRO 12 speakers for surround and overhead duties, and a staggering 18 THE28 subwoofers. Peter Aylett, CEDIA Fellow and Chair of the CEDIA/CTA-RP22 Immersive Audio Design Recommended Practice, says that the client already owned an extremely high-end private cinema but wanted something even better. "The client wanted the best private cinema in the world," Aylett explains. The homeowner requested proposals involving both the brand used in his existing theater and an alternative recommended by Cinema Buro. Aylett pointed to ASCENDO's engineering documentation, the firm's previous experience with the products, and the room's performance requirements as reasons the company was an obvious candidate.
Two additional winning installations are located in the United Kingdom. "Going Underground," designed by Cinemaworks in collaboration with Louise Tarling Ltd, took EMEA Best Home Cinema Level I honors. The eight-seat theater incorporates ASCENDO's THE10 and THE6 loudspeakers with four THE12 SUB PRO PASSIVE SEALED SHALLOW subwoofers, delivering a measured low-frequency response that's linear down to 17Hz. Meanwhile, "Deep House," designed by Dellicompagni, earned EMEA Best Home Cinema Level III recognition. Built within an existing room whose structure couldn't be altered, the 11.1.6 system uses 11 THE10 speakers, six THE6 PASSIVE WEDGE 30 speakers, and 12 THE16 subwoofers arranged in an eight-front, four-rear configuration. Trinnov WaveForming is used to manage the bass array, while a separate THE24 infrasonic subwoofer handles the lowest frequencies. The system was designed with CEDIA/CTA-RP22 Level 3 performance targets in mind.
Germany rounds out the list with Portofino Cinema, an installation by ARLED Solutions GmbH that received EMEA Best Home Cinema Level IV honors. This is a substantially larger theater, occupying approximately 100 square meters and featuring a 13.18.6 immersive audio configuration. ASCENDO equipment is used throughout, including five THE15 Be PRO on-wall speakers, eight THE12 on-walls, and six THE10 PASSIVE WEDGE 30 speakers. Low-frequency duties are handled by 16 THE21 SUB WF subwoofers, supported by two enormous THE32 infrasonic subwoofers. It's the kind of installation that illustrates just how far ASCENDO's product range can scale, from relatively compact dedicated theaters to rooms with the size and output requirements of a commercial screening facility.
"We publish our data because the best designers verify performance before they specify it," said Geoffrey Heinzel, Co-Managing Partner of ASCENDO. It's a philosophy that's clearly finding an audience among high-end theater designers, and one that's helping the company establish a growing international presence.
For additional information about the winning projects, visit ASCENDO's 2026 CEDIA Smart Home Awards page.
Related Reading:
