Andrew Slater
- Jul 6, 2017
- Messages
- 14
My AV System
- toslink into Dirac Live box, & 3 minidsp 2X4 HDs
- Main Amp
- Focal 4 ch bridged to HLCDs
- Additional Amp
- 2 JL audio 600/4 bridged mid midbass
- Other Amp
- jl audio HD1200/1 Sub
- clairion NX706 96k Nav Screen
- HE Horns, Mids, Midbass bEYMA, b&C
As title says I have 12ch of fir and 12x10ch of iir and a 2ch of upstream fir
12ch are 1024 samples at 96k
And upstream open is 3100 samples at 96k also (can be made to do 6100 samples at 48k)
my question is
Will audiolense be able to make a correction and put all 13 channels of fir into its system and be able to divide the delay taps how I want them to be made and output an fir for each device and respective channel.
i am hoping to build a correction that is all exclusive on the same set of measurements for each driver and have each correction for each channel compliment eachother
i want to do driver tuning and linear crossovers in the outputs and a global room and sum correction with the OpenDrc and have all channels and stuff be managed in audiolense and done all start to finish….
ive been using rephase for crossovers now and the iir channels on the outputs for driver tuning and using a Dirac ddrc22 for the summed correction…. I want to do it all manually and do it all together in one interface and not have to bounce between REW, Rephase , Dirac …..
I also want to adjust everything together for making and trying different things without having to start completely over like new measurements and stuff
will this do what I want ?
thanks in advance
my question is
thanks in advance
