Tgorle
- Jul 31, 2018
- 8
I've been using Equalizer APO to apply REW EQ profiles in Windows 10 using the WDM Stereo outputs into powered monitors, but my DAW is set up with MADI I/O, so here's a relatively cheap method to replicate the REW EQ's in a VST that can be applied last in the chain to the stereo master bus. The Voxengo Curve EQ plugin is about $79 and you can draw independent L/R curves so your monitoring environment remains consistent between DAW and Windows playback... (these are not perfect, but you get the idea). If anyone has better suggestions for VST plugin control in this situation, please chime in. Thanks!
