Vanco Introduces Dante Audio Adapters to Bring Legacy Audio Gear Into Networked Systems
Editor / Senior Partner
Baltimore/Washington Metro
Kaleidescape TERRA
OPPO UDP-203
Panasonic UB9000
Spotify
GoldenEar Invisa MPX
Quad Array SVS SB16s
JVC NZ8
Sony 65-inch A95L OLED
Sony 65-inch X900F
ZeroSurge 8R15W x 2
ZeroSurge 2R15W x 2
New compact adapters add Dante connectivity for analog, Bluetooth, ARC, and USB-C sources, helping integrators modernize without rip-and-replace.
Batavia, IL – May 19, 2026 – Vanco International LLC, an industry leader in AV distribution and electronic accessory products, today announces a new line of Dante Audio Adapters, designed to help integrators connect common audio sources and legacy gear into Dante-enabled systems quickly and cost-effectively.
These adapters allow integrators to instantly add Dante connectivity to any audio source or sink, dramatically expanding system design options. They also support mid-cycle system upgrades and enable applications to transition to Audio over IP without forcing a full system overhaul.
Each Vanco Dante Audio Adapter supports a single signal format, delivering a native connection experience for the source while providing a true Dante workflow for routing and distribution. The lineup includes:
  • Analog in/out
  • XLR (male and female)
  • Bluetooth input
  • ARC in/out
  • USB-C in/out (2x2)
As Dante-based workflows continue to expand beyond traditional large-scale audio environments, integrators are increasingly leveraging modern, networked distribution on both new and retrofit projects. These adapters help broaden what can live on a Dante backbone, turning non-Dante components into Dante-capable devices and expanding network audio opportunities in office buildings, hospitality venues,campuses, event venues, and houses of worship.
“We built these adapters because Dante demand keeps showing up in real projects, and customers want a straightforward way to tie legacy and new components together,” said Brandon White, Director of Product Development at Vanco. “It’s a small add-on that creates a big path forward for integrators.”
Visit www.vanco1.com to learn more.
