Cary B. Cornett
- Nov 7, 2020
- Messages
- 12
I will be using REW to test and set up monitors and subwoofer in my studio, possibly also using a MiniDSP 2x4 balanced for processing and crossover to sub. But before I pull the trigger on hardware, I need to know whether I can make UMIK-1 work in conjunction with the setup that drives my monitors. My studio computer is running Windows 10 LTSC. I use a MOTU 424 pci card with a 2408 MK III for the interface. Normally I am using the ASIO drivers, but I assume REW uses the regular Wave drivers that work with Windows. The question is, will REW (and my system) allow me to use the UMIK-1 as the input device while using the MOTU interface as the output device?
Alternatively, how accurate will readings made using an AKG 451 mic with the standard omni capsule? I'm talking about checking frequency response, not reading absolute SPL levels. I would be using a Presonus Digimax FS for preamp and A/D conversion.
