Rique Pagan
- Apr 11, 2023
- 5
- mixing/Pro Tools9 HD
- Main Amp
- Grace m904
- DAC
- grace
- Computer Audio
- 3 card TDM
- Adam S2.5A
Hello: I'm a beginner. My recording equipment is old and I usually don't use it for anything but tracking and mixing but one day: this is a 2009 Mac Pro Running OS 10.8.5, in order to use Pro tools 9 HD.
I installed rew on harddrive. Using Dayton USB mic, I set Rew up to use the optical output of Mac Pro (toslink) That went into Grace M904 and into my monitors I made pink noise test, adjusted sound to 80 db using Radioshack SPL, mic in place, set to 20-20,000 HZ, take measurment. Graph looks as expected. I delete it immedietly to do another because I was holding the mic in my hand but I can't do another because the Grace isn't working anymore.
The toskink input is gone, fried, I don't know. Can you see what I did wrong, from my discription?
Thanks, Rique
Thanks, Rique
