sendler2112
- DAC
- Burson Conductor Reference SE DAC/ Headphone amp
- Computer Audio
- WASAPI/ Foobar
- Other Speakers
- Hifiman Ananda Nano Headphones
I'm testing headphones with MiniDSP EARS. My listening chain is WASAPI/ Foobar with Math Audio Headphone EQ plugin/ USB/ Burson Conductor Reference/ HiFiman Ananda Nano Headphones. In Foobar preferences I select Burson XMOS USB Exclusive in order for the files to play straight out at the native bit rate ( The Burson indicates the incoming bit rate and I noticed that if I don't select "exclusive mode" that hirez 96k files are being received at 48k despite the selection of Burson WASAPI.)..
This WASAPI/ Foobar output is apparently not really the source of the sweep even though the output device menu is selected to be " EXCL Speakers 2 Burson XMOS". and it doesn't matter if the output menu is set to SPEAKER or default
Is there a way to get the test sweep to play through the EQ of Foobar. It definitely is not doing so now. I set a -20db and wide bell in both EQs in Foobar at 1k and the measurements SPL is unchanged.
