SPL meter Speaker Cal noise produces rapid pitch-warble / flanging ("whee, whee")
Lolke
Bryston BP20
Hypex UCD
Computer / Lynxtwo B
Linkwitz Orion
Home made
double JL Audio 12W7-3 on Behringer 3000DSP
Pioneer plasma
Hi everyone,
I am experiencing a specific audio artifact in REW when using the SPL meter with the Speaker Cal signal. Instead of steady pink noise, the output produces a fast-pulsing pitch modulation/flanging sound that repeats like "whee, whee, whee" at a rhythm faster than once per second.
Playing a steady single sine tone or regular music through the system sounds completely fine and clean. The issue only occurs with the SPL meter calibration noise.
System setup:
  • OS: Windows 11
  • Output: Topping D10s DAC (USB) -> miniDSP OpenDRC-DA8
  • Input: Audient iD14 interface + iSEMcon EMX7150 measurement mic
Observations and troubleshooting:
  • The rhythm of the modulation is uniform and repeats sub-second.
  • In REW Preferences (Java engine), devices are selected in [EXCL] mode.
  • Windows audio settings and REW are both set to 48 kHz.
  • Adjusting buffer settings in REW (up to 512) does not eliminate the cycling effect.
  • Power-cycling the hardware resets it, but the sound returns as soon as the SPL meter calibration signal starts.
Has anyone encountered this specific pitch-warbling issue on the SPL calibration noise, and how can it be resolved?
Thanks for any insights!
Update: I tested the Generator again, and Pink Periodic and White Periodic also produce the exact same "whee, whee, whee" pitch-warble/flanging effect. Regular sine tones remain completely fine.
That's not an artefact, it's how periodic noise sounds. Periodic noise gives more stable level readings, but you can switch to random noise on the soundcard preferences by deslecting this setting:
Ah, that explains it! I wasn't aware that the repeating nature of Periodic Noise would sound like that to the human ear.
I unchecked "Use periodic noise for SPL calibration" in the Soundcard preferences, and it immediately switched to standard random pink noise—smooth and steady without the cycling sound.
Thanks a lot for clearing that up!
