Some input on my first result
Easyrider
Hi there,
Can someone tell me what's going on here Please?
Just moved to a new space so decided to do a test.
Cheers
Using an ARC 2.5 Mem Mic and ID 22 calibrated inside REW
  • Soundcard Calibrated Test No treatment.mdat
Your soundcard cal is wrong, there was some monitoring active when it was generated which is why it has that bizarre shape.
45754
Easyrider
Is this right?
45756
Cheers
  • Soundcard.mdat
Easyrider
Is my room bad? :praying:
sm52
Normal graphs. I like. You just always need to turn on the 'invert' button. I think because of the microphone.
Easyrider
Is my goal just to try and get an even line?
Any context in my result would be great :)
sm52
Yes. But this is unreal. Therefore, your goal is to determine the position of the speakers in the room and among themselves so that there are fewer deep pits or high peaks in the graph.
