jtalden
- Marantz AV7705 Pre/Pro
- Main Amp
- VTV 6 chnl NC252MP P-amp x 2
- Additional Amp
- Behringer DCX2496 x 2
- OPPO BDP-103 Universal Player
- DIY SEAS H1456/H1212 Spkr x 5
- DIY JBL 2235H 15" SW x 2
- Screen
- Da-Lite Da-Snap 39105V - 92"
- Video Display Device
- JVC DLA-X790R
As you suggested below there are several possible delay settings that will result in favorable SPL support. Using the FDW on the phase in the alignment tool is just one way to determine which delay setting is closest to the conventional target timing where the direct sound phase response tracks as closely as possible throughout the XO range. When the SPL support is not favorable when the FDW is removed, then it is best to adjust the delay timing as need from that point to get favorable SPL.i am unfamiliar with the phase tab analysis , usually i align the subs using the impulse tab overlay with a separate measurements(with timing reference).
can you please further explain the principle of using the phase tab with FDW and its benefits ?
The method you mention below is a good an alternate method for this preliminary alignment. That is, align the initial rise the 2 impulses so they start at the same time then adjust timing from there as needed. Some people prefer to align the impulse peaks and adjust as needed from there. That can also result a favorable timing for SPL and sound quality. I have seen many impulse shapes that make this method less reliable for finding the conventional delay timing, but it often still works fine to find a favorable delay timing.
You can see the relative phase either by using the REW overlay phase chart or using the alignment tool.i have download the Sonnie's REW measurements ,but when overlay them at the phase tab - i just see the FR and the FL - don't see the SW,can you please advice on that ?
If you want to better understand the phase and alignment tool I suggest the exercises found here. That thread has a lot of discussion regarding the alignment tool.
There is nothing wrong with that method. It finds a favorable delay setting for SPL. If we are off by one cycle from the conventional target timing that is not likely to impact the sound quality very much. There are arguments that decreasing the delay of the SW by 1/2 or 1 cycle can sound better because there is less overall group delay. There a tradeoff of characteristics and it is difficult to know from a technical perspective what may sound better to an individual listener. I don't like to delay the SW more than a 1/2 cycle from the conventional target alignment as it is not longer a tradeoff and thus it is harder to see why that setting is more favorable from a technical perspective. I doubt that the sound quality is significantly different however.finally, i have always use the "sub distance tweak" (adjusting timing between the mains and subs) till i have got the flattest FR at XO region. i have read many times that you can have a very flat FR but still be off by one cycle (hence effect badly the sound quality and not being aware of that from the "graph") - what do you think of that ?its seems to me that this method of checking phase relationship between the mains and the subs -could help in that region .
