I have a series of impedance traces that I want to separate using "separate traces" tool in an overlay plot. But since the traces only move down/negative, they are off screen before they are sufficiently separated for easy viewing. And it seems there is no way to change the ohms scale to allow negative numbers so I can't bring the traces back on screen by changing the scale, like I would for SPL traces. Is there a way to allow the ohms scale to be negative? Or to separate trace "up" instead of down? Or is there some other way to separate impedance traces effectively?
Also, is that a way to add an offset to impedance traces like you can to SPL traces?
Thanks,
Eric
Thanks,
Eric
