Jan, perhaps not important for your testing scenario, but be aware that the single tone generator in REW can have its harmonic levels manually adjusted (using the Adjust harmonic levels tickbox). In a typical loopback scenario around a soundcard, adjusting the harmonics can realise an RTA response with harmonics suppressed into the noise floor. Although that pedantically doesn't mean the output of the soundcard has similarly suppressed harmonics, it does a pretty good job of making a distortionless signal source if the soundcards ADC and front end is blameless. I have tried that scheme to include an external power amplifier, but not to include a speaker and mic, although I'd anticipate if the speaker harmonics were dominant in that loop then they may be able to be similarly suppressed so as to derive an audible speaker signal with lower harmonics.
Perhaps another possible concern is that REW generates a tone frequency that may not be 'exactly' at the chosen Hz, especially if the 'Lock frequency to RTA FFT' box is ticked.
