3ll3d00d
- Jun 4, 2017
- 47
This behaviour seems a little odd to me, probably undesirable but also probably not commonly encountered & perhaps there is a different way to fix this.
Situation is a set of measurements taken on and off axis with a timing reference for speaker design. I forgot to set the offset in the measurement window so then have to shift all the measurements back a fixed amount one by one. Say I measure at 1m and shift each measurement by that amount using offset t=0 then the x axis moves ~3ms to the left per measurement hence you end up having to reset limits every few measurements.
This makes sense when looking at a single measurement (as you maintain the same visible range of the IR) but preserving that shift as you move from measurement to measurement seems a bit more dubious.
I can't personally think of a sensible way to handle this in the general case but I think there is a feature request here (or a feature I'm missing) which would be the ability to shift all IRs by a fixed offset in one go (which would then avoid this problem). Another related feature request, and possible alternative to me shifting like this, is the ability to specify the window in absolute terms rather than relative to the ref time.
