Quick question about using REW with a UMIK-1 and RME Fireface UCX.
finale27
Hello,
Is there any measurement performance benefit if the UMIK-1 is routed through the RME UCX instead of connecting it directly to the computer via USB?
Since the UMIK-1 has its own built-in ADC, I assume the best setup is:
Input: UMIK-1 (USB directly to PC)
Output: RME Fireface UCX → speakers
Just want to confirm if that’s the correct or optimal configuration.??
Thanks!
How?
It's the only option you have with that equipment. Optimal configuration would be to get a XLR mic and plug it into your audio interface.
