whoareyou
- Dec 23, 2021
- 235
- Main Amp
- Benchmark AHB2
- Additional Amp
- ATI AT525NC
- DAC
- Exasound E38
- Computer Audio
- JRiver
- Psb synchrony one
- Center Channel Speaker
- PSB synchrony one C
- Surround Speakers
- Revel m105
Hi,
Was wondering about correct way to handle the LFE channel when ripping the multichannel tracks on these pure bluray audio disks.
If you played the physical disk on a bluray player, it will go through the hardware and LFE channel will be processed with the 10db boost.
So, if you've ripped the tracks off of the disk, it seems you should apply the proper LFE boost somewhere in the chain for playback. Or is there something different about these disks?
Also, if LFE is ov concern, then what about the PCM tracks that most of these disks provide? Are these already 10db LFE corrected?
