ProMedia Lumina 2.1 Review: Living with Klipsch’s New Desktop System for 4 Months!
Manufacturer & Model
Klipsch ProMedia Lumina 2.1 Desktop Speaker System
MSRP
$379.99
Link
https://amzn.to/4tJCpVc
Highlights
2.1-channel desktop speaker system, redesigned MicroTractrix horn tweeters, dual 3" midrange drivers, 6.5" side-firing subwoofer, Bluetooth 5.3, USB-C audio connectivity, 3.5 mm analog input, Klipsch Connect Plus app support, six-band EQ, customizable RGB ambient lighting, Virtual Surround processing, adjustable speaker tilt, 100W RMS / 200W peak amplification, compact nearfield design, MDF subwoofer cabinet, multiple sound presets, Night Mode, Windows Klipsch Control software support
Summary
Klipsch’s ProMedia Lumina modernizes one of desktop audio’s most recognizable product lines with a compact 2.1-channel system that blends energetic nearfield sound, modern connectivity, and customizable software features into a surprisingly refined package. Redesigned horn-loaded tweeters, a dedicated side-firing 6.5" subwoofer, and extensive EQ controls allow the system to deliver an engaging presentation for music, movies, gaming, and everyday desktop use. Add in Bluetooth 5.3, USB-C connectivity, RGB lighting, and app-based controls, and Lumina positions itself as a far more mature and flexible solution than the average PC speaker system while still maintaining the lively sonic character that has long defined Klipsch products.
Back in 1999, Klipsch helped redefine desktop audio with the launch of its ProMedia 4.1 speaker system, the world’s first THX-certified computer speaker package. At a time when most PC speakers were plasticky and largely forgettable, ProMedia arrived with horn-loaded tweeters, a true dedicated subwoofer, and sonic energy that pushed far closer to home audio than traditional computer accessories.
Now, some 26 years later, Klipsch is back with a complete refresh of the formula: ProMedia Lumina, a modernized 2.1 desktop speaker system designed to appeal to everyone from gamers and content creators to music fans and PC media consumers. Bluetooth and USB-C connectivity, app control, and customizable ambient lighting have become part of the equation, positioning the system to balance modern conveniences with the distinctly energetic audio personality that has long defined Klipsch products.
System Overview
ProMedia Lumina stands as a relatively straightforward 2.1-channel system. Each satellite speaker houses a 1" Mylar tweeter mated to Klipsch’s patented MicroTractrix horn technology, positioned over a dedicated 3" midrange driver. Klipsch says the horn has been redesigned with a wider geometry specifically optimized for nearfield desktop listening. The company also claims the system delivers improved efficiency and controlled dispersion, helping create a more focused listening experience at close distances.
Handling low frequencies is a slim, upright active subwoofer armed with a side-firing 6.5" woofer paired with a front-firing port. Factory specs pinpoint the system’s frequency response at 40Hz to 20kHz (-6dB), while onboard amplification is rated at 100 watts RMS and 200 watts peak. According to Klipsch, crossover points sit at 150Hz for the sub and 3.5kHz for the midrange on the satellites.
Connectivity has been modernized substantially compared to older ProMedia generations. The system supports Bluetooth 5.3, USB-C, and a traditional 3.5mm analog connection. There’s also onboard app support through Klipsch Connect Plus on iOS and Android, along with Klipsch Control software for Windows users (a slight miss for the Mac crowd). App functionality includes a six-band EQ, multiple sound modes, subwoofer level adjustment, lighting customization, Virtual Surround processing, and key system controls for firmware updates, factory resets, and the like.
The question, of course, is whether this latest ProMedia system successfully delivers something that’s genuinely compelling in today’s crowded desktop landscape. Over the past several months – yes, months – I’ve had an opportunity to pace ProMedia Lumina through daily use in my 1,200 cubic foot home office, using it for music, movies, and content creation. After spending considerable time tweaking placement, experimenting with the onboard EQ, and even taking a few measurements with Room EQ Wizard, I’ve come away with a good understanding of where this system excels, where its limitations live, and who it’s designed for.
Setup, Design, and App Experience
Out of the box, Lumina presents itself as an extremely approachable system. Inside the packaging, you’ll find two satellite speakers, a sub, dedicated speaker and USB-C cables, and a quick-start guide. Klipsch’s packaging here is competent and confidence-inspiring. The entire system ships double-boxed, secured in custom-fitted foam molds and protective wrapping. Clearly, this is a product intended for broad consumer deployment, and Klipsch has done a commendable job ensuring everything arrives protected and ready to rip.
One of the first things that immediately stands out during setup is the system’s overall footprint, which remains compact and manageable. Nothing here feels oversized or cumbersome, and that latter point extends directly into the installation process itself. Both satellite speakers arrive with their stands permanently attached and proprietary speaker cables pre-installed. Those stands allow for subtle angle adjustments between 0 and 20 degrees, which might initially seem like a minor detail but, in actual use, becomes critically important. Because these speakers are heavily optimized for nearfield listening, proper toe-in and tweeter alignment toward your ears materially impacts imaging and tonal balance.
Each speaker cable gives you 6.5' of length, and while a proprietary all-in-one cable design won’t appeal to everyone, I actually found its implementation to be fairly smart in practice. Rather than tethering one speaker to the other in an active/passive configuration, both satellites connect directly to the subwoofer's rear. In real-world use, this simplifies cable management considerably. Instead of dealing with power cables, interconnects, and additional speaker runs across the desk, you’re left with a two-cable install that terminates into the sub using proprietary 90-degree screw-in connectors. Those connectors are a nice touch if you’re hoping to position the subwoofer close to a wall, though the power cord lacks a 90-degree connector, creating a need for a slightly larger rear gap.
Set-up genuinely couldn’t be much easier. Plug the satellites into the subwoofer, connect power, choose your source, and you’re operational within minutes. There’s very little technical complexity involved, and honestly, that ease of deployment is one of the system’s notable strengths. Whether you’re a hardcore enthusiast or someone simply looking to improve the sound coming from a desktop setup, Lumina is highly approachable.
Visually, the system lands somewhere between an understated classic look and a modern gaming aesthetic. The satellites use ABS plastic construction and feel appropriate for the category. Nobody is going to mistake them for handcrafted wood veneer monitors, nor do they try to present themselves that way. Instead, Klipsch leans into a sleek Carbon wood-grain vinyl wrap paired with silver front baffles that add nice visual pop.
On a desk, these speakers look sharp.
The satellites have a narrow form factor that works extremely well in practical use. Positioned on either side of my 24" Mac, the speakers left plenty of usable desk space for lamps, books, accessories, and general workspace organization. That’s something surprisingly few desktop speaker reviews talk about, but for people actually living with systems like this, desk real estate matters.
The subwoofer carries a more substantial feel thanks to its MDF construction. Physically, it measures 14" T x 6" W x 13 7/8" D, making it relatively slender for a sub. Its side-firing 6.5" driver works alongside a front-firing port, and all system routing occurs directly through the subwoofer rather than a primary speaker, which I personally preferred from both a usability and cable-management standpoint.
Physical controls are kept refreshingly straightforward. The rear of the sub houses a dedicated gain knob positioned just above USB-C and 3.5mm analog inputs. The knob actually feels a bit cheap thanks to its lightweight plastic construction, but it does offer a tactile notched feel when turned, which helps provide some level of repeatability during adjustments.
The right satellite speaker also has physical controls, making it the primary interaction point for daily operation. On top sits a multifunction button that controls power and lighting, while a second rear-mounted button cycles through source inputs and handles Bluetooth pairing duties. Because of these controls, most everyday interactions can be handled directly without having to constantly launch the app.
Speaking of the app, Klipsch’s Connect Plus application is surprisingly robust. My review was conducted using firmware version 1.01, and throughout testing, the app remained stable and responsive. The interface itself is clean and intuitive, giving you access to a master volume slider accompanied by plus and minus buttons for finer adjustment. Bluetooth playback controls are integrated directly beneath that, followed by input selection for Bluetooth, analog, USB, and PC modes.
A six-band equalizer gives owners adjustment points at 50Hz, 150Hz, 400Hz, 1kHz, 5kHz, and 8kHz (±12dB). Klipsch also includes several factory EQ presets, including Flat, Vocal Boost, Bass Boost, Treble Boost, Rock, and Hip-Hop, alongside a fully customizable user preset. Throughout my listening, I kept gravitating toward the Bass Boost profile. In my office environment, that setting added welcomed warmth and low-end body, better balancing the overall presentation for both music and movie content.
Additional app controls include Movie, Music, and Virtual Surround modes, Night Mode toggling, lighting customization, power management settings, firmware updates, and a dedicated subwoofer gain slider ranging from -20dB to +10dB. For this review, I set the subwoofer gain to -2dB in both Flat and Bass Boost modes.
Lighting customization is extensive but thankfully tasteful. Each satellite includes a rear frosted light panel that diffuses illumination softly onto a surface behind your desk. Available modes include Rainbow, Breathe, Static, Aurora, Music React, and PC Control. While the Music React mode felt somewhat frenetic and distracting to my eyes, the Static mode became my preferred configuration. With brightness reduced to roughly 30% and a dark blue hue selected, the system cast a subtle ambient glow behind my desk, adding atmosphere without screaming for attention.
Bluetooth implementation proved excellent throughout testing. Pairing was fast and reliable, and the system properly retained memory for previously connected devices. Once paired with my iPhone, Lumina would automatically reconnect within seconds whenever Bluetooth mode was selected. Signal stability was also impressive. Streaming Spotify Lossless produced no meaningful dropouts or glitches, even while moving between rooms. Also, volume control through connected devices remained responsive and predictable.
Sound Quality and Performance
When it comes to actual sound quality, ProMedia Lumina unmistakably sounds like a Klipsch product. The sats' horn-loaded tweeters deliver a crisp, energetic presentation with excellent transient attack and sharp imaging capabilities. Proper setup matters tremendously here. Toe-in is absolutely critical. Once properly aimed toward the listening position, the system produces a surprisingly coherent stereo experience.
During critical listening, I reached for several familiar tracks to evaluate imaging performance, including The Cars’ “Let’s Go” and Pink Floyd’s “On the Run.” Both songs highlight Lumina’s ability to place sounds precisely within a stereo field while maintaining an engaging sense of energy and movement. Especially at close distances, the speakers throw an impressively focused image.
Of course, any discussion of Klipsch and horn-loaded tweeters inevitably circles back to concerns about listening fatigue. The company’s sound signature has long had far more fans than detractors, but there’s definitely an ongoing conversation surrounding brightness and long-session listenability. Personally, I tend to be particularly sensitive to bright loudspeakers, but I never found ProMedia Lumina to drift into the kind of shrill or overly aggressive presentation that can sometimes plague more energetic designs. And importantly, the app's EQ adjustments give you enough flexibility to subtly pull back upper-end energy if desired. So, from my perspective, fatigue never became an issue.
That said, the system reveals some of the inherent tradeoffs associated with nearfield designs. For example, off-axis performance isn’t particularly forgiving. Move too far outside the primary listening position, and high frequencies noticeably roll off. The sweet spot here is very much your desk chair, so keep that in mind if you're considering Lumina for more traditional room listening.
Vocally, the presentation lands solidly within expectations for a $379 desktop system. Using Norah Jones’ Come Away With Me as a reference point, her smoky vocal delivery retained enough warmth and smoothness to remain satisfying, though without the deeply etched microdetail and texture weight you’d expect from significantly more expensive systems.
Perfect? No. But more than respectable given the price tag.
The Sub
Now, let’s talk about the subwoofer because this is probably where expectations need the most calibration. Klipsch officially rates the system down to 40Hz (-6dB). In my room, using REW measurements and some experimentation, I found usable in-room extension landed closer to 45Hz. Honestly, for a slim 6.5" desktop-oriented subwoofer, I wouldn’t expect much more. That’s not to say your experience couldn’t be different. A smaller room might lend itself to a bit more low-end rumble, and corner loading the sub could potentially coax a few additional dB in the lower 40Hz or upper 30Hz range. Unfortunately, my desk layout simply didn’t allow for that kind of placement experimentation.
Measurements and experimentation show the crossover landing around the published 150Hz mark, and because of that relatively high crossover point, some bass localization exists. There were certainly some moments where I remained consciously aware that I was listening to a desktop 2.1 system rather than a more fully integrated full-range speaker solution. Fortunately, this rarely became distracting so long as the subwoofer remained floor-mounted and positioned relatively close to the satellites. In my setup, placing the subwoofer directly beneath the left speaker yielded surprisingly coherent integration without obvious lag or disconnected bass.
Most importantly, the subwoofer doesn’t attempt to artificially overwhelm the room with exaggerated bass. Instead, it provides enough foundational weight to give music, gaming, and movie content proper scale and breadth. And it does so while maintaining composure at all but the most extreme volume level. So, hats off to Klipsch for engineering Lumina to deliver a smartly controlled low-end punch that isn't shy about playing loud.
Ultimately, that’s probably the best way to understand ProMedia Lumina as a whole. This isn’t a miniature audiophile monitoring system pretending to compete with multi-thousand-dollar studio setups. It’s a thoughtfully engineered, highly approachable desktop audio solution that dramatically outperforms the vast majority of traditional computer speakers while remaining easy to live with day in and day out.
Final Thoughts
The combination of simple deployment, strong nearfield imaging, flexible app support, tasteful industrial design, modern connectivity, and energetic sonic character makes Lumina a fun system to enjoy. Yes, setup matters. Proper toe-in matters. Placement matters. Spend a little time dialing in those elements, and the reward is an engaging desktop audio experience that feels considerably more mature than the “gaming speaker” label might initially suggest.
At $379.99, ProMedia Lumina lands at an attractive middle ground between mass-market PC speakers and more serious powered desktop monitor systems. For users looking to elevate their desktop audio experience with something compact, modern, fun, and genuinely capable, Klipsch’s latest evolution of the ProMedia concept proves there’s still plenty of life left in the category it helped create over two decades ago. Recommended!
Amazon has the Klipsch ProMedia Lumina on sale for $60 off: https://amzn.to/4tJCpVc
Klipsch ProMedia Lumina 2.1 Speaker Specifications:
  • Channel Configuration: 2.1-Channel
  • Speaker Configuration: 2-Way
  • Drivers: 1" Mylar tweeter and 3" horn midrange (per speaker)
  • Frequency Response: 40 Hz to 20 kHz (-6 dB)
  • Inputs / Outputs: USB-C audio/charging passthrough, 3.5 mm audio passthrough
  • Subwoofer Driver: 6.5" side-firing woofer
  • Bluetooth: Bluetooth 5.3
Speaker System
  • Enclosure Type: Sealed
  • Amplifier Power Rating: Not specified by manufacturer
  • Crossover: 3.5 kHz
  • Maximum SPL: 90 dB
Subwoofer
  • Enclosure Type: Bass-reflex
  • Crossover Frequency: 150 Hz
Wireless Connectivity
  • Wireless Protocols: Bluetooth
  • Bluetooth Version: 5.3
Power
  • Input Power: 100 to 240 VAC, 50 / 60 Hz
Physical
  • Color: Black
  • Cabinet Material: ABS, MDF
  • Dimensions (L/R Speakers): 6.5 x 9.7 x 4"
  • Dimensions (Subwoofer): 14 x 6 x 14"
  • Weight (L/R Speakers): 2.0 lbs each
  • Weight (Subwoofer): 10.8 lbs
Packaging
  • Package Weight: 24.3 lbs
  • Box Dimensions: 16.7 x 16.5 x 15.8"
Note, AV Nirivana is member and reader supported. We may make a small commission from affiliate links at no additional charge to you.
