Greetings to John and other forum participants.
To begin with, I want to express my deep gratitude to John for creating and supporting REW, the world's best acoustic measurement instrument (in my opinion).
A month ago, I purchased UMIK-1 directly from miniDSP, pleased with the quality of the microphone, a long cable in the kit and two calibration files. I used it for a while to measure room resonances and for this purpose the microphone works fine.
But I wanted more - the correct measurement of the phase of the speaker system with its subsequent correction in rePhase.
For phase measurement, I use the "Use acoustic timing reference" mode with a measurement length of 1M in REW. The mixer in Windows 10 is configured according to the instructions (48/24 output), no other programs work in the background. The microphone stands on a tripod, aimed exactly at the speaker system, a distance of 1.14 m. The room is quite quiet, the background noise level is about -60 dB. All conditions for correct measurements are met.
The audio path is quite simple: a desktop computer, via USB it is connected to the Audiolab M-DAC DAC, then the Genelec G Three active speaker system is connected via the balanced output. The computer has 3 different USB controllers: a built-in Intel chipset (USB 2.0), an ASMedia controller (USB 3.0) soldered on the motherboard, and a PCI-E card on a NEC controller (USB 3.0). All USB ports on all controllers are fully operational (any devices in them work correctly).
But when measuring the phase in REW, I came across the fact that the result very much depends on which USB controller I turn on UMIK-1. This manifests itself in a very different form of the impulse response and in the form of a phase curve. Repeatedly rechecked all software settings, the quality of cables, connections, and more. The difference in measurements appears only when changing the microphone controller, M-DAC does not react in any way to changing the controller.
Here are graphs of the impulse response and phase curve depending on the controller in which I include UMIK-1. For a correct comparison, I manually aligned t = 0.
Intel:
ASMedia:
NEC:
To finally make sure that the problem is not in a specific computer, I installed REW on a Lenovo X1 laptop and connected to it via USB both UMIK-1 and M-DAC. The result is similar to NEC, but still significantly different:
Based on the analysis of the pulse shape, you can reject the option with the ASMedia controller - there the pulse shape and phase curve are frankly incorrect, but the other three options are similar to the truth. The problem is that I can’t determine which of the measurements corresponds to reality - the difference in the length of the phase curve differs by hundreds of degrees, which, when you scan the curve in rePhase and generate the pulse file for the convolver, significantly affects the sound.
And I would like to understand why there is such a difference or what I am doing wrong.
I ask for help in solving the problem, I am enclosing the measurement files.
Intel:
ASMedia:
NEC:
