NeilBlanchard
- Apr 25, 2020
- 8
- Audible Illusions Modulus 2C
- Main Amp
- Schiit Audio Vidar
- Linaeum LT1000
After dealing with the graphics issues, I did manage to run the EQ to try and improve the response on the woofers and tweeters, and I created those files for my 2x4HD. But, when I load them into the unit, it says the file only has 325.25 factors, and up to 1024 are supported. For other files, the 325.25 number was something else, but the error (?) message was the same gist.
And after it is loaded - the line stays entirely flat. So, it seems like the file REW creates is not compatible with the 2x4HD? The file is a .txt file - is that correct?
I will try on the other computer that does not have the graphics issues, and maybe everything will be better then?
