Please help interpret these measurements
ddlooping
UK
Denon AVR-X3600H
Def Tech Mythos ST-L
M&K S-85
MK K4
Boston Acoustics SoundWare Cube XS
BK XLS200
Hi all :)
The below measurements are from left and right front speakers (crossed-over to 40hz with a sub).
If you look where I added some turquoise lines it seems like they are in "opposite phase" (I don't know the correct term) to each other.
Is it because of incorrect delay/distance settings in the AVR or something else?
Any help would be appreciated.
45744
sm52
This is a common thing. That the right side plays differently from the left. Due to the different reflections in the room for the left side and the right side.
ddlooping
UK
Denon AVR-X3600H
M&K S-85
MK K4
BK XLS200
