Okto dac8 pro - channel routing
tcode
Yamaha A/S 2100
JCAT USB XE, Singxer SU-2, JCAT Optimo Duo
Genelec 8330A
Genelec 7350A
Can anyone help me how to properly setup Audiolense XO channel routing to Okto Dac 8 Pro?
I have a 3-way stereo system and set the speaker setup to 2.0 stereo, added bass, midrange, and tweeter crossovers for each channel into the configuration, assigning them Channel IDs from 0 to 5.
When I try to run a speaker connection check, I only get sound on Okto channel 1 when testing the front left bass, and on channel 4 when testing the front right bass.
If I test Okto as a 5.1 surround device in the Windows Control Panel, I get sound and an indication that all outputs are active.
What am I doing wrong?
Thanks in advance!
Hmn, it seems that problem occurs only on testing. When doing measurement, getting signal on speakers correct.
Not sure my setup arrangements will help, but I do use my Okto dac8pro for 2.1, 5.2 and 5.1.2 listening. Screenshots attached. JCR
Thanks. I ended up by getting RME Fireface UCX II as my measurement ASIO device and everything works charming. Getting perfect measurements and no problem whatsoever.
Great piece of gear this one. Do you use it for playback too?
Yea, it is awesome, measurements are perfect. Didn't try it for playback because it doesn't support DSD which I prefer over PCM.
