Nov18,2025 A1 Evo Express Mac -> Problems
dclive
Denon S760H
S760H
NO
NO
NO
Music Server
PLEX
PLEX
NO
AppleTV
Turntable/Cartridge
No
No
No
SVS Ultra Evolution Bookshelf
NO
SVS Ultra Evolution Center
Sony SS8
NO
NO
NO
NO
SVS PB1000 Pro
Bass Shaker System
NO
NO
LG 75"
NO
Video Processor
NO
NO
Cables
NO
NO
NO
Network/Internet
1GB
Headphones/IEMs
NO
Headphone DAC/Amp
NO
Whole House System
NO
Office/Study System
NO
When I run A1E I get:
--- Starting Full, Automated Workflow ---
[Step 2/4] Measuring System...
'Single' microphone position measurement sequence
IMPORTANT:
• Ensure the calibration microphone jack is securely plugged into the front panel of your receiver.
• Place the microphone at your primary listening position (ideally should be centered between between the left and right front speakers).
• Microphone tip should be at seated ear height and pointing straight up at the ceiling.
How many times do you want each speaker measurement repeated?
(Measurement averaging improves signal-to-noise ratio by √(number of repetitions) in dB terms, elimination will be more aggressive but Express session will take proportionally longer)
• Fastest: 1 -> To confirm your setup is working correctly before committing to multiple sweeps.
• Fast: 2-3 -> Very quiet rooms
• Recommended: 4-6 -> Good balance of speed and accuracy
• Slow & Safe: 7-9 -> Noisy environments
• Slowest: 10-99 -> Severe OCD
>> Evo Express analyzes measurement data in real time, automatically corrects for clock drifts and discards noisy / unreliable measurements. A detailed report is presented when all measurements are completed for each channel.
✔ Enter the required number of measurement repeats per speaker/sub (1-99): · 1
Ensuring AVR is powered on and responsive...
-> AVR is responsive on Telnet port.
Connecting for measurements - checking if calibration mic is plugged in & headphones are disconnected...
-> Reset AVR state...
-> AVR state was reset...
-> Waiting for AVR to fully recover from state change...
-> AVR state reset. Waiting for it to settle...
-> Calibration microphone plugged in - passed.
-> No headphones connected - passed.
AVR has 'fixedA' data type. Re-ordering channels based on the required AVR sequence.
Starting sweeps immediately (numRepeats = 1).
--- Beginning Measurement Sequence ---
Entering measurement mode...
!!! Timeout/Error: ENTER_AUDY - No response/ACK received
---!!! MEASUREMENT PROCESS FAILED !!!---
Error: ENTER_AUDY: No response/ACK received
Closing AVR connection...
--- A1 Evo Express FAILED ---
Please check your speaker connections, power stages of ext. amps & subs, amp / speaker assignments in the receiver, turn off HDMI CEC or disconnect potentially problematic HDMI devices and then restart the application.
? >>> Press [Enter] to close the application. ›
____
Anyone have any ideas?
On the AVR side, shortly before it shows TIMEOUT/ERROR that you see above, the entire AVR crashes. In other words, I plug in the mic, it passes the " -> Calibration microphone plugged in - passed." stage, then the screen clears and it goes into an Audyssey like calibration screen, and then it hard-hangs. No moving back and forth with arrows/cursor control will move anything, exit out of the setup mode, or do anything else - with mic plugged in or not at that point. The only thing I can do on the remote is power it off. Powering it on again, I tried this again; exact same thing.
Note that it didn't find my AVR automatically - I had to key in IP:
A1 Evo Express
Next-gen sound calibration for 'everyone' by OCA
Before you begin:
1. Install REW: Ensure a recent **beta** build of 'Room EQ Wizard' is installed
Download link: (url removed)
2. AVR Set Up: Verify 'Speaker config.' and 'AmpAssign' match your active channels
3. Check Speakers: Ensure correct speaker wiring, polarity, tilt and positioning
4. Prepare Subwoofer(s): Turn off any internal processing, set power to 'On' (not 'Auto'), LPF dial all the way up
5. Prepare Room: Minimize room noise (AC, fans), close all doors and windows
6. Connect Mic: Plug AVR calibration microphone into the receiver's front panel
✔ >>> Press [Enter] when ready to start... ·
--- Starting A1 Evo Express ---
[Step 1/...] Discovering your receiver in the network and reading system configuration...
Searching for AV receivers via UPnP (Timeout: 5s)...
-> Found: Denon Denon AVR-S760H at 192.168.1.64
Found 1x distinct device description(s).
Filtered down to 2 potential AVR description(s).
Found 2 unique IP address(es) associated with potential AVRs.
Multiple potential devices found. Please select your AVR from the list.
✔ Found 2 potential AV receiver(s). Select target device: · Denon Upstairs - Denon (Aios 5.0V) [192.168.1.64]
UPnP discovery did not automatically identify a target AVR.
This can happen if the AVR is busy (e.g., active HDMI link with a TV) or due to limited network availability (e.g., Firewall or VPN).
✔ Please enter your AV Receiver IP address manually: · 192.168.1.64
Using manually provided IP: 192.168.1.64
Attempting to verify/find model name via /goform/ endpoint on 192.168.1.64...
Failed to get x x x x /goform/formMainZone_MainZoneXml.xml. Status: 301 Moved Permanently!
Could not get a valid model name from /goform/ endpoint.
Could not automatically determine a valid AVR Model Name for 192.168.1.64.
✔ Please enter the correct AVR Model Name (e.g., SR6011, X3800H): · S760H
Model name: "S760H" (Source: Manual Entry (User Provided))
Establishing connection to AVR...
√ Connection successful.
AVR reported active channels: FL, C, FR, SLA, SRA, SW1
AVR reported 'Amp Assign' mode: Zone2
Please make sure that ALL options under the receiver's 'Amp Assign' & 'Speaker Config.' menu match your current set up.
These settings will be treated as FINAL and will be used during the measurement, optimization, and calibration transfer steps!
✔ Have you reviewed and confirmed that all of these settings are correct in the AVR menu? · yes
√ Amp Assign setting confirmed.
√ Discovered AVR and its configuration successfully.
>> A1 Evo Express ready to start
Press ENTER to start Express Calibration (Measure → Optimize → Transfer)
Or type "T" to transfer an older Express calibration (.oca file) to your receiver
>>> Continue with Express? (Enter) or Transfer existing (T):
Anyone?
