Mckanan
- Nov 11, 2020
- 2
- RME Fireface 400
- Main Amp
- Autoamplified monitors Yamaha HS50 + subwoofer
- Center Channel Speaker
- Yamaha subwoofer
- Yamaha
Dears,
First of all I would like to congratulate you and thank you for what you are doing! it is a great tool that I have been recommended to use it by the specialist in sound treatment I am working with for my room/home studio treatment.
I would like to ask for your support because I can not make the REW getting the Mic input from my RME fireface 400 interface. I am using Macbook Pro with OSX 10.6.8, REW 5.01beta20, and an external mic (Neumann km 84). I set up at default all, and in the mac book I set up as default the first mix input of the interface. It works in the OS preference tab signal (also in the interface sound check light, plus in software such as Logic 9), but it does not enter into REW.
I did a try selecting in the laptop the internal mic, with same settings in REW (default) and it worked, so seems that it just does not work with the interface input. Also the sound calibration has some clicks (I tried increasing the buffer but still...).
Thank you so much for your support in advance.
Regards.
Regards.
