Yes we can. REW is like, well is, an Acoustic Laboratory. If you can post your REW file .mdat we can help display it's messages for you.
However, the ear and brain and language are pretty good too. Some details of your room, photos, diagrams would be useful. And our speakers?
Jumping the gun perhaps, but in my experience the single biggest and most frequent issues in treated rooms are are lack of bass, and unusually clear treble.
We often listen mid height and mid width, in two nulls. Speakers are often a few feet from the Front Wall, causing a further LF null.
Absorption will probably dull the HF of the room, but the removal of HF cancelling Early Reflections causes extreme clarity in the path from tweeter to ear.
Although contra popular opinion and practice, placing the speakers close to, almost touching, the wall, is a really cheap solution!
Similarly, if you have biamp speakers, turning down the HF, or inserting a simple resistor, can help.
DRC such as Dirac enables one to create a pleasing listening curve. Research shows this to be quite radically tilted by about 6dB from HF down to LF.
