Minidsp 2x4 hd vs avg meassurement
Thomas Larsen
Hi saw on minidsp homepage that their tutorials has changed regarding REW and subwoofer meassurements. They recommend that you meassure more e.g. 3 positions and then use the avg. response for yor EQ. How many use that ? I always only use one position in the MLP and eq that.
The multi position thing is kind of the audyssey way of doing.
Pros / cons of both ?
Wayne A. Pflughaupt
Corpus Christi, TX
Canton Karat 920
Canton Karat 920
Canton Plus D
Hsu ULS-15 MKII
Stock Yamaha Remote
Roku Express
I’m a MLP-only guy for manual EQ. After that, I personally I’ve always found the SQ perfectly acceptable in other locations – can’t tell a difference at any seat on the couch, even though they all measure a bit different.
Never have used Audyssey.
JStewart
Central FL
Makes sense as the sub response can change a bit even just a few inches away.
There’s also the “moving mic method” of measuring a response to eq.
sam_adams
Just remember to use the Vector Average when averaging responses to include the phase data for creating EQ filters.
Greg Dunn
One day I was curious about how well the moving mic technique matched averaged swept measurements. I have used only MMM for the last year or two because it is so easy and quick to set up, but I wondered...
So what I did was take about a dozen separate swept measurements at the LP, and at surrounding points about a foot away - in front, behind, above, below. These measurements looked about as different as you might expect. I then vector averaged them and got a composite average response. Then I ran a MMM with pseudorandom noise, very carefully, transiting the same volume I had just used for the swept tests. In both cases, I was measuring from about 15 Hz up to around 15 kHz (my hearing's upper limit).
The result? My MMM amplitude response was essentially identical to the averaged set.
I have manually (as well as using REW) created filters based on the MMM result, and the outcome was audibly the same. I have no reason to doubt the MMM results in my room, and it's almost trivially easy to get a measurement that correlates well to what I hear. As long as you take care to set it up properly and use pseudorandom noise, I have no problem recommending it for subwoofer setup.
pmar4015
Denon 8500HA
3 Outlaw Audio 2220 (powering Main L/R/C)
None
None
None
Internal - Denon 8500HA
Sony UBP- X700/M 4K Ultra HD Home Theater
Revel Proforma3 F208
Klipsch R-5800-W II (behind an AT screen)
None
ELAC Debut 2.0 OW4.2
Dayton Audio MK442T
Top Front L/R: Revel IW65
Klipsch AW-400
SVS PB-1000 (4 of these)
Gaming: XBOX X; Blu-ray Player: Sony UBP- X700(M)
Sony VPL-VW325ES
106” Perforated/Acoustically Transparent
Apple TV 4K (2021 Model/2nd Generation)
Apple Music; HBOMAX; Disney; Showtime; STARZ;Hulu; Paramount Plus; Netflix
Hardware DSP: MiniDSP 2X4 HD (Managing 4 subs)/Software DSP: MultEQ-X
Will you please provide your REW RTA settings? Thank you
dcibel
I'm not Greg obviously, but here's some settings I've used for room average RTA, aka moving mic method.
Use pink periodic noise generator, keep a constant pace of movement with the mic so you take about same number of measurements in each location. Once complete, save and apply psychoacoustic smoothing, for full range EQ >200Hz, use target slope of 0.7dB/oct.
FargateOne
Rotel RSX-1562
Bryston 3B3 for fronts mains
Cambridge CXU
B&W 804 D2
B&W HTM4D2
B&W 705
Samsung UN55ES8000
miniDSP 2x4 HD
I never came back after having discovered MMM for EQ my system. Better for less filters used and better for inner peace of an audio-OCD person!
pmar4015
Denon 8500HA
None
None
None
None
Dayton Audio MK442T
Klipsch AW-400
Sony VPL-VW325ES
Many thanks! very helpful
