Thank you for the suggestion. Here are some measurements I just made.You'd need to attach or provide a link to an mdat file for anyone to comment.
All the sweeps sounded the same. My surround speakers don't have multiple tweeters. All of my speakers are very close to the walls.Looks like something went awry with the first measurement. A dropout, perhaps. Did the sweep sound normal for that one?
Surrounds aren't always a good choice as the timing reference, they are often close to walls with strong reflections and some have multiple tweeters.
More than 3 m?Long HDMI or USB cables
I actually use a high quality 8 meter USB extender. I'll try without the extension.Long HDMI or USB cables can also cause issues sometimes.
