IMD Measurements: "Generator" vs "Input" Level Discrepancy
Can you please fix this as well?
The file chooser is a Java runtime component, so in this case the Linux runtime is deciding the sort order. They sort alphanumerically on Windows. Are you using the REW version that includes a runtime? If not, which Java runtime are you using? You can see it listed at the top of the About REW dialog.
I'm actually using the version without runtime. And it's interesting that the help window says I have a Full HD screen, while I'm using a UHD one.
The screen size reported to the application is after scaling has been applied. All icons now use multi resolution images, with entries for scale factors of 1.0, 1.25, 1.5, 1.75 and 2.0. The runtime should automatically choose the correct image version for the display scale factor. You can try and force things by adding a VM option:
-Dsun.java2d.uiScale=1.5
Thanks for that tip, and setting the font size to 21 got the interface back to how it was before, except for the icons and waveform being a bit smaller, but I can live with that.
When I press Capture graph image in RTA window and then press Save button, this appears:
REW V5.40 Beta 110 running Eclipse Adoptium JRE 11.0.29 64-bit on linux 6.17.1-surface-2 Language uk, country UA, keyboard UA, UTF-8 Screen 3840 x 2160 at 168 DPI Running in /opt/REW
Message:
Stack Trace:
javax.help.plaf.basic.BasicTOCNavigatorUI.presentData(BasicTOCNavigatorUI.java:244)
javax.help.plaf.basic.BasicTOCNavigatorUI.access$100(BasicTOCNavigatorUI.java:75)
javax.help.plaf.basic.BasicTOCNavigatorUI$NavSwingWorker.finished(BasicTOCNavigatorUI.java:267)
com.sun.java.help.impl.SwingWorker$1.run(SwingWorker.java:133)
java.desktop/java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:313)
java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:770)
java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721)
java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715)
java.base/java.security.AccessController.doPrivileged(Native Method)
java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85)
java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:740)
java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:117)
java.desktop/java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:190)
java.desktop/java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:235)
java.desktop/java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:233)
java.desktop/java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:233)
java.desktop/java.awt.Dialog.show(Dialog.java:1070)
java.desktop/javax.swing.JFileChooser.showDialog(JFileChooser.java:769)
roomeqwizard.components.P.showDialog(y:2249)
java.desktop/javax.swing.JFileChooser.showSaveDialog(JFileChooser.java:691)
roomeqwizard.GA.D(y:892)
roomeqwizard.GA.B(y:3129)
roomeqwizard.GA.A(y:47)
roomeqwizard.GA.C(y:1011)
roomeqwizard.components.wA.A(y:684)
roomeqwizard.components.wA.A(y:2548)
roomeqwizard.components.wA$15.actionPerformed(y:3266)
java.desktop/javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1967)
java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2308)
java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:405)
java.desktop/javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:262)
java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:279)
java.desktop/java.awt.Component.processMouseEvent(Component.java:6635)
java.desktop/javax.swing.JComponent.processMouseEvent(JComponent.java:3342)
java.desktop/java.awt.Component.processEvent(Component.java:6400)
java.desktop/java.awt.Container.processEvent(Container.java:2263)
java.desktop/java.awt.Component.dispatchEventImpl(Component.java:5011)
java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2321)
java.desktop/java.awt.Component.dispatchEvent(Component.java:4843)
java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4918)
java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Container.java:4547)
java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Container.java:4488)
java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2307)
java.desktop/java.awt.Window.dispatchEventImpl(Window.java:2772)
java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:772)
java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:95)
java.desktop/java.awt.EventQueue$5.run(EventQueue.java:745)
java.desktop/java.awt.EventQueue$5.run(EventQueue.java:743)
java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:742)
java.desktop/java.awt.Component.show(Component.java:1716)
java.desktop/java.awt.Component.setVisible(Component.java:1663)
java.desktop/java.awt.Window.setVisible(Window.java:1031)
java.desktop/java.awt.Dialog.setVisible(Dialog.java:1005)
roomeqwizard.components.hB.setVisible(y:1459)
roomeqwizard.components.wA.D(y:1421)
roomeqwizard.components.eB$3.actionPerformed(y:2234)
java.desktop/java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:298)
java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
Strange, it seems to be failing inside a Java runtime class that's trying to access some help. Are other file choosers OK? Can you post a screenshot of the Capture dialog before pressing save?
