How to eq sub only and intergrate with mains
Joffieb
Rotel RC995
Rotel RB981
Modi 3
Audioengine B-Fi
Tidal, Spotify
B&W 685s2
AE Aegis Neo V2
MiniDsp nanoDigi 2x8
Hi
I am running Harbeth P3ESR's and a B&W ASW675 sub. I want to integrate the sub and want to interfere with the Harbeths as little as possible. I am running a MiniDSP 2x4 into the sub so can do time alignment and 5 band eq as well as setting a crossover. I'm looking for advice how to integrate the sub only eq'ing the sub by using measurements. So far, if I measure the sub alone and apply the generated filters, once the full system is measured, the low end where the speakers and sub play together flops.
Any advice please.
Thank
The best way to keep subs from interfering with the main speakers is to high pass the latter, thereby allowing the subwoofer to handle the bass range alone.
Lacking that, your best bet would be to run REW on your Harbeths to determine where they roll off at the low end. Then, either low pass the sub to operate below them, or if intentionally overlapping the two, only EQ the sub below the Harbeth’s operating range.
Thanks,
I have managed to calculate a delay to add to the sub using a MiniDsp that has removed one wide null between 115Hz and 155Hz.
I can't eq or HP crossover my mains separately. Also, not sure how to spot the roll off as there's a dip and then the lower peak may be a room mode.
So my problem is that I can't work out filters to only apply to the MiniDsp on the sub because of the overlap with the mains. If I just measure the sub and create filters, the mains at those frequencies are ignored for the filters and if I measure the full system but only apply the filters to the sub, the mains at that frequency are not filtered.
I've attached my measurements with my progress so far.
Yes, I understood the problem from what you described in your first post.
Give us a full-range measurement of each of your main speakers separately. I'll take a look and see if I can give you an idea of where they roll out.
The specs for the Harbeth P3ESR are: A Two-way, sealed-cabinet, stand-mounted loudspeaker. Drive-units: 0.75" (19mm) magnetically shielded, aluminum-dome tweeter; 5" (110mm) magnetically shielded, Radial2-cone woofer. Frequency response: 75Hz–20kHz, ±3dB. Nominal impedance: 6 ohms ("easy to drive"). Sensitivity: 83.5dB/2.83V/m. Recommended amplification: >15W. Power handling: 50W program...
As this is published information I would still suggest you take your own measurements as Wayne suggests...
Thanks guys,
Here are the speaker only measurements
