How to calibrate REW - IMPEDANCE
Sacenti
Could someone help me please?! After I installed the latest version of REW 5.20.14 - I can measure everything about SPL but nothing else works to measure impedance this java message always appears blocking the calibration measurements! what am I doing wrong? In the previous version 20.13 I was still able to do this quickly and safely but now I can't...
Despite using the main signal through the Left port of my Latitude E6410 notebook sound card (I did this before with no problems) the connections seem to be correct as below and the REW tutorial allows you to do the impedance using the main port for the Left channel.
Below is the REW file of the calibration attempt I would appreciate someone's help if possible! Thanks
  • Impedance open cct.txt
  • Impedance open cct.mdat
Please click the Details button, copy the text to the clipboard and paste it here.
Sacenti
Hi John! First of all, thank you for your prompt response to all of us on the forum!
I think I got the right information requested!
SoundCard Debug Data generated by REW V5.20.14 running Oracle Corporation JRE 1.8.0_361 64-bit on Windows 10
Locale: language pt, keyboard BR, windows-1252 at 96 DPI
Dated: 30/03/2023 08:01:03
Input Device: Line In Mic (High Definition Audio Device)
Input: MICROPHONE (Volume principal)
Input Volume: 0,250
Output Device: Alto-falantes (High Definition Audio Device)
Output: SPEAKER
Output Volume: 0,500
Output Mute: Off
Wave Volume: No control
Wave Mute: Off
Sample rate: 48000
0: EXCL: Alto-falantes (6- Creative Sound Blaster), WASAPI, 1, Alto-falantes
Line interface SourceDataLine supporting 2 audio formats, and buffers of at least 32 bytes (max. 1 simultaneously):
0: PCM_SIGNED 48000.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
1: PCM_SIGNED unknown sample rate, 16 bit, unknown number of channels, unknown frame size, little-endian (-1 channels, frameSize=-1, little endian)
[no controls]
Line interface Clip supporting 2 audio formats, and buffers of at least 32 bytes (max. 1 simultaneously):
[no controls]
1: EXCL: Saída de SPDIF (6- Creative Sound Blaster), WASAPI, 1, Saída de SPDIF
[no controls]
[no controls]
2: EXCL: Alto-falantes (High Definition Audio Device), WASAPI, 1, Alto-falantes
Line interface SourceDataLine supporting 12 audio formats, and buffers of at least 32 bytes (max. 1 simultaneously):
0: PCM_SIGNED 88200.0 Hz, 32 bit, stereo, 8 bytes/frame, little-endian (2 channels, frameSize=8, little endian)
1: PCM_SIGNED 48000.0 Hz, 32 bit, stereo, 8 bytes/frame, little-endian (2 channels, frameSize=8, little endian)
2: PCM_SIGNED 44100.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
3: PCM_SIGNED 192000.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
4: PCM_SIGNED 96000.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
5: PCM_SIGNED 192000.0 Hz, 32 bit, stereo, 8 bytes/frame, little-endian (2 channels, frameSize=8, little endian)
6: PCM_SIGNED 88200.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
7: PCM_SIGNED 44100.0 Hz, 32 bit, stereo, 8 bytes/frame, little-endian (2 channels, frameSize=8, little endian)
8: PCM_SIGNED 96000.0 Hz, 32 bit, stereo, 8 bytes/frame, little-endian (2 channels, frameSize=8, little endian)
9: PCM_SIGNED 48000.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
10: PCM_SIGNED unknown sample rate, 16 bit, unknown number of channels, unknown frame size, little-endian (-1 channels, frameSize=-1, little endian)
11: PCM_SIGNED unknown sample rate, 32 bit, unknown number of channels, unknown frame size, little-endian (-1 channels, frameSize=-1, little endian)
[no controls]
Line interface Clip supporting 12 audio formats, and buffers of at least 32 bytes (max. 1 simultaneously):
[no controls]
3: EXCL: Entrada de SPDIF (6- Creative Sound Blaster), WASAPI, 1, Entrada de SPDIF
Line interface TargetDataLine supporting 3 audio formats, and buffers of at least 32 bytes (max. 1 simultaneously):
0: PCM_SIGNED 44100.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
1: PCM_SIGNED 48000.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
2: PCM_SIGNED unknown sample rate, 16 bit, unknown number of channels, unknown frame size, little-endian (-1 channels, frameSize=-1, little endian)
[no controls]
4: EXCL: Entrada de linha (6- Creative Sound Blaster), WASAPI, 1, Entrada de linha
LineUnavailableException when trying to open this line
[no controls]
5: EXCL: Line In Mic (High Definition Audio Device), WASAPI, 1, Line In Mic
Line interface TargetDataLine supporting 12 audio formats, and buffers of at least 32 bytes (max. 1 simultaneously):
10: PCM_SIGNED unknown sample rate, 32 bit, unknown number of channels, unknown frame size, little-endian (-1 channels, frameSize=-1, little endian)
11: PCM_SIGNED unknown sample rate, 16 bit, unknown number of channels, unknown frame size, little-endian (-1 channels, frameSize=-1, little endian)
[no controls]
6: EXCL: Microfone (6- Creative Sound Blaster), WASAPI, 1, Microfone
[no controls]
7: EXCL: Wave/MIDI/CD (6- Creative Sound Blaster), WASAPI, 1, Wave/MIDI/CD
[no controls]
8: Driver de som primário, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
Line interface SourceDataLine supporting 8 audio formats, and buffers of at least 32 bytes (max. -1 simultaneously):
0: PCM_UNSIGNED unknown sample rate, 8 bit, mono, 1 bytes/frame, (1 channels, frameSize=1, little endian)
1: PCM_SIGNED unknown sample rate, 8 bit, mono, 1 bytes/frame, (1 channels, frameSize=1, little endian)
2: PCM_SIGNED unknown sample rate, 16 bit, mono, 2 bytes/frame, little-endian (1 channels, frameSize=2, little endian)
3: PCM_SIGNED unknown sample rate, 16 bit, mono, 2 bytes/frame, big-endian (1 channels, frameSize=2, big endian)
4: PCM_UNSIGNED unknown sample rate, 8 bit, stereo, 2 bytes/frame, (2 channels, frameSize=2, little endian)
5: PCM_SIGNED unknown sample rate, 8 bit, stereo, 2 bytes/frame, (2 channels, frameSize=2, little endian)
6: PCM_SIGNED unknown sample rate, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
7: PCM_SIGNED unknown sample rate, 16 bit, stereo, 4 bytes/frame, big-endian (2 channels, frameSize=4, big endian)
Controls[0]: FloatControl: Master Gain with current value: 0.0 dB (range: -80.0 - 6.0206)
Controls[1]: BooleanControl: Mute Control with current value: False
Controls[2]: FloatControl: Balance with current value: 0.0 (range: -1.0 - 1.0)
Controls[3]: FloatControl: Pan with current value: 0.0 (range: -1.0 - 1.0)
Line interface Clip supporting 8 audio formats, and buffers of at least 32 bytes (max. -1 simultaneously):
[no controls]
9: Alto-falantes (High Definition Audio Device), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
[no controls]
10: Alto-falantes (6- Creative Sound Blaster), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
[no controls]
11: Saída de SPDIF (6- Creative Sound Blaster), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
[no controls]
12: Driver de captura de som primário, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
Line interface TargetDataLine supporting 8 audio formats, and buffers of at least 32 bytes (max. -1 simultaneously):
[no controls]
13: Line In Mic (High Definition Audio Device), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
14: Entrada de SPDIF (6- Creative Sound Blaster), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
15: Entrada de linha (6- Creative Sound Blaster), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
16: Microfone (6- Creative Sound Blaster), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
17: Wave/MIDI/CD (6- Creative Sound Blaster), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
18: Port Alto-falantes (High Definition , Unknown Vendor, 0.0, Port Mixer
Port SPEAKER target port
Controls[0]: BooleanControl: Mute Control with current value: false
Controls[1]: FloatControl: Volume with current value: 0.5000076 (range: 0.0 - 1.0)
Controls[2]: CompoundControl: Áudio CD Control containing Mute, and Volume Controls.
MemberControls[0]: BooleanControl: Mute Control with current value: false
MemberControls[1]: FloatControl: Volume with current value: 0.5000076 (range: 0.0 - 1.0)
Controls[3]: CompoundControl: Volume principal Control containing Mute, and Volume Controls.
19: Port Alto-falantes (6- Creative Soun, Unknown Vendor, 10.0, Port Mixer
20: Port Saída de SPDIF (6- Creative Sou, Unknown Vendor, 10.0, Port Mixer
Port Volume principal target port
21: Port Entrada de SPDIF (6- Creative S, Unknown Vendor, 10.0, Port Mixer
Port Volume principal source port
Controls[0]: CompoundControl: Volume principal Control containing Mute, and Volume Controls.
MemberControls[1]: FloatControl: Volume with current value: 0.7537194 (range: 0.0 - 1.0)
Controls[2]: CompoundControl: Volume principal Control containing Mute, and Volume Controls.
22: Port Entrada de linha (6- Creative S, Unknown Vendor, 10.0, Port Mixer
Port LINE_IN source port
23: Port Line In Mic (High Definition Au, Unknown Vendor, 0.0, Port Mixer
Port MICROPHONE source port
MemberControls[1]: FloatControl: Volume with current value: 0.2500038 (range: 0.0 - 1.0)
24: Port Microfone (6- Creative Sound Bl, Unknown Vendor, 10.0, Port Mixer
MemberControls[1]: FloatControl: Volume with current value: 0.4599985 (range: 0.0 - 1.0)
25: Port Wave/MIDI/CD (6- Creative Sound, Unknown Vendor, 10.0, Port Mixer
MemberControls[1]: FloatControl: Volume with current value: 1.0 (range: 0.0 - 1.0)
Attached USB devices
ID: 58f Product: 6254
ID: 8087 Product: 20
ID: 46d Product: c52f
ID: bda Product: 8771
ID: 258a Product: 1006
ID: a5c Product: 5800
ID: 8086 Product: 3b34
ID: 5ac Product: 12a0
ID: 5ca Product: 1814
ID: 41e Product: 3010
ID: 8086 Product: 3b3c
ID: 58f Product: 9254
  • 1 check leves cal Imp open cct soundcard_debug.txt
  • 2 test start cal Imp soundcard_debug.txt
No, it isn't that file.
Which 5.20.14 build have you installed? The build is the digits after ea in the filename. It may be easier to just download the latest build from the first post of the 5.20.14 early access thread.
If you get the error message with the latest build then when the error message appears there is a Details button on the message. Click that button, then click the button that says Copy to clipboard to copy the details to the clipboard and paste that here.
Sacenti
John, could you please send me the link where to download this version, please? I don't have this on my pc anymore!
"latest build from the first post of the 5.20.14 early access thread."
Tks
Sacenti
Thanks John! I'll try to reinstall and post!
John did the reinstallation of Rew the old one was 5.20.14ea12 by the new one sent REW_windows-x64_5_20_14ea47, the calibration was apparently good, no more Java error, but is the speaker measurement too weird? 70 Ohms is not right! what I'm doing is wrong now my God!
SoundCard Debug Data generated by REW V5.20.14 running Azul Systems, Inc. JRE 1.8.0_362 64-bit on Windows 10
Dated: 30/03/2023 16:47:08
Input Volume: 0,750
Output: SPEAKER
Output Mute: Off
Wave Mute: Off
Sample rate: 48000
[no controls]
[no controls]
[no controls]
[no controls]
0: PCM_SIGNED 96000.0 Hz, 32 bit, stereo, 8 bytes/frame, little-endian (2 channels, frameSize=8, little endian)
1: PCM_SIGNED 88200.0 Hz, 32 bit, stereo, 8 bytes/frame, little-endian (2 channels, frameSize=8, little endian)
3: PCM_SIGNED 44100.0 Hz, 32 bit, stereo, 8 bytes/frame, little-endian (2 channels, frameSize=8, little endian)
4: PCM_SIGNED 48000.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
5: PCM_SIGNED 192000.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
6: PCM_SIGNED 48000.0 Hz, 32 bit, stereo, 8 bytes/frame, little-endian (2 channels, frameSize=8, little endian)
7: PCM_SIGNED 96000.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
8: PCM_SIGNED 88200.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
9: PCM_SIGNED 192000.0 Hz, 32 bit, stereo, 8 bytes/frame, little-endian (2 channels, frameSize=8, little endian)
[no controls]
[no controls]
[no controls]
[no controls]
[no controls]
[no controls]
[no controls]
[no controls]
[no controls]
[no controls]
[no controls]
[no controls]
[no controls]
[no controls]
[no controls]
[no controls]
[no controls]
MemberControls[1]: FloatControl: Volume with current value: 0.7499962 (range: 0.0 - 1.0)
  • 30_3 debug REW_windows-x64_5_20_14ea47 soundcard_debug.txt
You seem to be having trouble attaching the measurement, perhaps the file is too large. If your question is whether a speaker measurement can have a high impedance peak, then the answer is yes. This one is nominally a 6 ohm speaker.
BenToronto
Good lab practice is to "test" a non-inductive resistor of known value and see what you get.
Sacenti
Hi John! I tirelessly tested various types of measurements Impedance, impulse, frequency, etc... and nothing strange in Java happened in that version you sent me! I had the 5.20.14ea12 with problems only in the impedance measurement... now the REW is great and stable again for me in this new version 5.20.14ea47!
Thank you for your usual promptness and attention to REW forum participants!
