how can see port noise in measures, or how measure port noise best ?
user44455555
Hi
In this thread https://www.audiosciencereview.com/...d-which-extension-is-best.72895/#post-2663074 girtab bring suggestion to measure port noise
I try it and when use generator 58 hz sine i hear it clear and loud and much diffrence between 66 db and 84 db output at 1 meter set, but the measures did not show much diffrence. I measure at 4 cm distance and little from side so that the air did not flow direct in microphone. Only there can see much jumps in group delay
