REW Beta Release Help with changing the sweep configuration for a multiple mic measurement
Seth Siegel
I'm trying to alter the sweep configuration for the multiple mic measurement to be the same as that of a single mic. To do this I am trying to set the smoothing to "None" and the step size to 0.36621097. However, I see that the measure/sweep/configuration call does not support this. Is there another call in the measure section of the API that would allow for this to be done? I've taken a look through the measurements section, but would prefer to make this change before the sweep has run and not after.
A multi-input average uses log spaced data, that's why when you export it as text you see the 96 PPO spacing. You can export any measurement as log spaced by choosing that option on the export dialog.
Seth Siegel
Is there a way to make a multi-input average use linearly spaced data? I don't see that as an option in the export screen, just differing PPO values.
No, it uses log spaced data to keep the file size manageable since it contains each individual response as well as the average.
