Behaves normally for me, so I'd suspect it could be a disagreement between Java and the graphics card. Your Java runtime is a little old, 8u91, so worth trying to update that. There was also an update to the V5.19 installer on the 27th August, if you downloaded before that worth re-installing. If neither of those fix it try the workaround in this thread.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
