Resource icon
REW Beta Release Getting Started with REW - A Step-by-Step Guide 2017-06-03
You Must Login or Register to Download
Sonnie Parker
Music Server
ROON Nucleus One
Magnetar UDP800 UHD Player
Lenovo X1 Carbon
Turntable/Cartridge
Music Hall Stealth Turntable
Ortofon 2M Blue Cartridge
Zero Surge 8R15W-1
Zero Surge 2R20W
JTR Noesis 110HT
JTR Kallos (Custom Built)
JTR Noesis 210RT
JTR Noesis 210RT
JTR Noesis 110HT-SL
JTR Noesis 110HT-SL
JTR Noesis 110HT-SL
Bass Shaker System
Dayton Audio BSA-200 Amp
4 BST-1 Bass Shakers
Wharfedale Super Linton
URC MX-890
Cables
AudioQuest - Various
THX PixelGen HDMI
Pangea Power Cables
Blue Jeans Cables
SVS Soundpath Cables
Custom Cables
None
Network/Internet
C-Spire 500MB Fiber
Omada OC300 Controller
Omada ER8411 10G Router
Asustor Flashstor NAS
Headphones/IEMs
HIFIMAN HE1000se
Unique Melody Mest MKII
Headphone DAC/Amp
Eversolo DMP-A6
RME ADI-2 DAC FS
HIFIMAN Goldenwave Serenade
Whole House System
HEOS System
Home-150 Speaker x6
Samsung S9 Tablet w/ HEOS
Office/Study System
Office System
Dell Precision Computer
Roon Networked
AV Test Room System
NAD M33 Streaming DAC Amp
MartinLogan Motion XT F200
JTR Captivator RS1
miniDSP EARS
Zero Surge 8R15W-1
Zero Surge 2R20W
Dell Optiplex
Roon Networked
Additional Room System
Sunroom System
Zu Audio DW-6 Speakers
Roon Networked
Dish Joey
JVC 37" TV
Cabin System
Onkyo TX-SR805 Receiver
Infinity Primus P163 Speakers
Shield TV Pro
Sony 55" TV
Vinyl Room
Technics SL-1210GR2 Turntable
KLH Model Three Speakers
Zero Surge 8R15W-1
Barn Jam
Soundfield Custom Speakers
Hi everyone
Looking for help
I have fully active klipsch La Scala II's speakers running of a xilica XP4080
Recently I have moved rooms so the original settings that the crossover have loaded don't work in the new room, I have taken sweeps of all six drivers using REW but I'm now lost as to how to create PEQs and load them into my Xilica it's well over my head
Is there anyone that can help me by looking at the sweeps and converting them to PEQs to be uploaded to my Xilica
Any advice or help would be greatly appreciated
I'm happy to pay for this service,
Cheers
Deano
Help I went with recommendation of the steinberg ur22c and the daytonaudio mic but can’t work out or find how to wire this up thanks for any help
The UR22C connects to the computer via its USB cable. You need an XLR microphone cable to connect the mic to one of the UR22C mic inputs and phantom power needs to be turned on to power the mic.
Thank you John did you use to work for TAG mclaren
Was it that long ago so sad they pulled out met you a few times at the factory hope you are well
do I then run a cable from other output to the amp
thanks Neale
Yes, use one of the outputs to connect to the system being measured. Make sure the mix knob is turned all the way to DAW to disable input monitoring.
I just started reading the REW guide. i have a few questions with starting the set up.
I am using windows 11
1. Under the microphone properties/level, when I set my microphone level to 81%, it puts me at +15 dB. This number is not shown on the guide and I want to verify if this would be correct in using windows 11?
2. Under the HDMI output properties/enhancements tab, I do not have a tab that says enhancements. I’m assuming there’s not another location where I should be accessing this to make sure the enhancements are turned off?
3. Under speaker configurations, I have the option to choose Dolby Atmos surroundsound. I am currently running a 7.2.4 system. I know in the guide it shows to select 7.1 system, but I’m assuming with this upgrade on windows 11 I should select the Dolby Atmos system for my set up?
One more question. What is the most current version of the The Getting Started with REW Step-by-Step Guide?
The author, AustinJerry, no longer supports that document or others that he created. His explanation (from Dec 2022) for dropping them can be found here and here.
However his last (current) version of his doc remains on dropbox (Rev 6.5 12/31/2022). I believe most of what is in that doc is still valid with the latest REW version.
https://www.dropbox.com/s/51jpnxet3bvew2k/REW 101 HTS Current Version.pdf?dl=0
REW doesn't directly support Atmos height channels, so I would select the 7.1 system. However you can use functions within REW to measure them.The Dolby Atmos and REW thread discuses this and the Dolby Atmos Height Channels Measurement & Calibration with REW youtube video explains how it is done and links to the files you would need.
I don't use Windows 11, so I can't help with that.
