crossrh
- Monoprice HTP-1
- Main Amp
- Monoprice 7X, for LCR and Subs
- Additional Amp
- ICEpower 50ASX2SE Class D Amps (5 ea.) DIY'd
- Oppo UDP-203 disc player
- Zaph Audio SB12.3
- Center Channel Speaker
- Zaph Audio ZD3C
- Surround Speakers
- All Dayton Audio
- FI IB318 (2 ea.) 18" IB Subs
- Video Display Device
- Epson 6050UB projector
- Screen
- Carada 108" screen
- Remote Control
- Harmony Elite
I'm using the Alignment Tool in the All SPL control panel to try to fix the phase issues that Dirac left me with. (My L,C, and R, all Zaph Audio designs, have 2nd order crossovers, and thus reverse-polarity drivers, and this is throwing Dirac for a loop. They're aware of it, but haven't offered any solutions yet.)
Is there a preferred frequency range I should use during the sweeps to get the most accurate info? Is the range different for full-range speakers vs. subs? Is there anything else I should know about this process? I'm using the farthest-distance speaker (SBL) as the Acoustic Timing Reference.
On a side note, my Land R speakers are sealed, but my C speaker is ported, and my Subs are IB. Would this make it harder to match phases, or reduce the frequency range that I could hope to get a good phase match? I can rebuild the Center speaker into a sealed design, but I'd like to know if it's worth it, from a phase-matching perspective.
Rick
Rick
