Filter Format 32 vs 64bit. Anyone Hear a Difference?
whoareyou
Benchmark AHB2
ATI AT525NC
Exasound E38
JRiver
Psb synchrony one
PSB synchrony one C
Revel m105
I hear no difference- at least with JRiver
What are people using and why? Just curious.
There is zero possibility of hearing a difference, though many people think they do. Head over to AudioScienceReview.com and check out a wide range of DAC reviews. Each one analyzes the filters provided and shows which differences are possibly audible. The biggest benefit is to filter ultrasonics so you don’t stimulate tweeters and create IMD in the audible range. Never any impact whatsoever at the low end, DAC chip filters don’t kick in until 15k to 22k Hz anyway.
Ultrasonic filters can be implemented with similar practical precison in 32 or 64-bit format.
LF filters have coefficients that require increased resolution. think what rounding can do to 20Hz opposed to 20,000 Hz. However, as I wrote earlier, I seriously doubt anyone would hear it.
There is often a DC eliminator set at about 1Hz. And there maybe signal processing along the way, like cross-overs.
