Error During Measurement Using exaSound s88 DAC
sledwards
I have setup a 6-channel measurement (2 mains and 4 subs) using separate input and output devices, Mic in is thru a Focusrite Scarlett USB using Focusrite AISO driver. Output thru the DAC uses exaSound 8-channel AISO64 driver:
I am able to perform 'Check Speaker Connections' without any issues. When I 'Run Measurement', I get the following Windows error:
Any suggestions would be helpful. Hopefully my fallback is not having to buy an 8-channel sound card with combined input/output.
Steve
Omid
Try different combination of drivers rather than ASIO for both playback and input.
e1guapo
Drop THX AAA 789
HQPlayer Embedded / Desktop, Roon
Merging+Anubis, Denafrips Ares II, SPL Phonitor One d
PreSonus E5 XT
PreSonus E44
PreSonus E3.5
PreSonus E3.5
PreSonus E8
Sennheiser HD820, HD650, Beyerdynamic DT880 Pro
iFi ZEN Stream
Qobuz, Tidal, Apple Music
Audiolense XO, SoundID Reference
You can’t use two ASIOs at once. You can ether use one ASIO + one WDM or use ASIO4ALL for two different devices.
sledwards
Good catch e1guapo, I had learned that earlier but forgot. Unfortunately I have another issue. To actually get it to perform sweeps, I had to increase the channel count from 6 to 8, even though I had no output on two of my channels. It then failed the quality check, I assume because of the two null outputs. Oh and BTW, AISO4ALL does not work for output.
