- Onkyo TX-SR705 Receiver
- Main Amp
- Crown XLS 1502 DriveCore-2 (x2 as monoblock)
- Additional Amp
- Behringer A500 Reference Power Amplifier
- MartinLogan Electromotion ESL Electrostatic (x2)
- Center Channel Speaker
- Phantom Center
- Surround Speakers
- NSM Audio Model 5 2-Way (x2)
- JBL ES150P Powered Subwoofer (x2)
Dual-banana connections used to be so standard. The electrostatics from MartinLogan have a different spacing between the positive and negative terminals so the dual plugs will not fit. I have had to pull the dual-banana connectors off of my cables at the speaker end and replace them with single-banana connectors.
The manufacturer of the AVR I started working with recently did the same thing, spaced the speaker connectors so dual-banana will not fit. So now I am pulling off connectors at the amp end and replacing them with single bananas. What gives? I always thought dual banana connectors worked great. Is this some sort of a plot?
