Denon output device not available
jdurb
Denon 4300H
Opo 203
SVS Ultra Bookshelfs
SVS Ultra Center
Rythmik FV 18
I was able to see Denon as an output device last night but now its not available. I'm connected to a Denon 4300H with front auxiliary HDMI.
41490
jdurb
Denon 4300H
Opo 203
SVS Ultra Center
Rythmik FV 18
ASIO is installed but Java is selected. Denon was just available again after a restart and after another computer reboot it isn't. Is this an HDMI cable thing or something?
jdurb
Denon 4300H
Opo 203
SVS Ultra Center
Rythmik FV 18
Or Windows isn't working with the Denon? Denon doesn't show up in Sound Control either. The laptop desktop does show up on the TV
sam_adams
With your AVR and UMIK connected:
Open Control Panels.
Click on Sound.
On the Playback tab, right-click in the blank, white area below all displayed devices.
Select 'Show Disabled Devices' and 'Show Disconnected Devices' from the pop-up menu.
Does the AVR appear in the device list as disabled or disconnected?
Unplug the HDMI cable.
Plug it back in.
Does the AVR appear in the device list as enabled?
jdurb
Denon 4300H
Opo 203
SVS Ultra Center
Rythmik FV 18
I'm at work now. I asked in another forum too and he said HDMI doesn't work with Java. But I've seen Java work on YouTube channels so I tried it. Confusing to me but I'll try ASIO tonight.
On Windows the Java drivers only offer stereo, so you can only access the left and right channels of an HDMI connection (all channels are available on macOS or Linux though).
sam_adams
There is a new beta of ASIO4All that is Windows 10 specific and is indicated as solving some issues. Try the latest Beta when you download.
jdurb
Denon 4300H
Opo 203
SVS Ultra Center
Rythmik FV 18
Still no Denon showing up. Tried disconnecting & reconnecting the HDMI cable. Laptop is connected to Aux1 on front of Denon
41651
sam_adams
Some users have reported that the Aux 1 input on Denon AVRs can be a bit flaky. Try one of the inputs on the back and see if the laptop picks it up.
jdurb
Denon 4300H
Opo 203
SVS Ultra Center
Rythmik FV 18
I see the Denon under Software devices in Device Manager
41652
jdurb
Denon 4300H
Opo 203
SVS Ultra Center
Rythmik FV 18
Oh thanks Sam. That may be it! I've seen the Denon appear in REW once. That may explain it. I'll try in a bit.
jdurb
Denon 4300H
Opo 203
SVS Ultra Center
Rythmik FV 18
You were right! Aux 2 on back worked. Thanks
