- Manufacturer & Model
- Denon DP-500BT Bluetooth Turntable
- MSRP
- $899
- Highlights
- Belt-drive turntable, semi-automatic operation, Bluetooth transmission, SBC, aptX, aptX HD, and aptX Adaptive support, built-in switchable phono stage, 33⅓, 45, and 78 RPM playback, S-shaped tonearm, removable universal headshell, moving magnet cartridge, die-cast aluminum platter, RCA output, USB recording, removable dust cover, automatic tonearm lift at the end of playback
- Summary
- The Denon DP-500BT blends traditional vinyl playback with the flexibility of modern wireless audio. Its built-in phono stage, Bluetooth transmitter, removable headshell, and three-speed operation make it easy to integrate into a wide range of systems, while strong wired and wireless performance give it appeal for newcomers and experienced vinyl listeners alike.
Priced at $899, Denon’s new DP-500BT can work like a traditional turntable, but it also carries features that make it easy to drop into a wide range of systems. Those who already own a phono preamp can send the cartridge’s raw signal out to their preferred external gear. Those who don’t can flip a switch on the rear panel and use the DP-500BT’s built-in phono stage, allowing the turntable to connect directly to a receiver, integrated amplifier, or powered speakers.
There’s also a twist. A secret weapon that makes the DP-500BT stand apart: Bluetooth transmission. With an internal Bluetooth transmitter onboard, the turntable can send music directly to compatible headphones and speakers, giving vinyl playback a little more freedom than the usual fixed listening seat and analog cable path. Codec support goes beyond standard SBC, adding advanced options like aptX, aptX HD, and aptX Adaptive for use with compatible wireless gear.
Denon hasn’t ignored the traditional side of the equation, either. Hidden beneath its headline-grabbing Bluetooth capabilities is a belt-drive design with a die-cast aluminum platter, an S-shaped tonearm, a removable headshell, semi-automatic operation, and support for 33 1/3, 45, and 78 RPM playback. In other words, this isn’t a basic record player armed with Bluetooth. It’s a turntable designed to work across several different kinds of systems while leaving room for future cartridge and phono stage upgrades.
Of course, versatility only matters if the fundamentals hold up. The DP-500BT still needs to deliver stable playback, resist unwanted vibration, and sound good enough to justify its price tag. So, has Denon successfully loosened vinyl’s traditional restraints without compromising the qualities that make records worth playing in the first place?
Let’s find out.
Out of the Box
Assembling a turntable can be intimidating, especially for someone unfamiliar with a component that depends on proper setup to perform its best. Platter installation, belt placement, tonearm balance, and tracking force all matter, and there’s not a lot of wiggle room for mistakes. Fortunately, the DP-500BT makes assembly approachable, with a clearly illustrated quick start guide that walks first-time owners through each step in a logical order.
Setup begins by lowering the die-cast aluminum platter onto the center spindle and looping the drive belt around the motor pulley. Denon makes the latter step especially easy by attaching a small red ribbon to the belt, allowing it to be pulled into position without awkwardly reaching through the platter. From there, the platter mat drops into place, the supplied headshell and cartridge assembly twists onto the end of the tonearm, and the counterweight threads onto the rear.
The most technical part is balancing the tonearm, then selecting the proper tracking force and anti-skating settings. No biggie, though, as Denon provides recommended values for the included cartridge and clearly explains how to dial them in.
That leaves one final step: installing the dust cover, which slides into a pair of hinges at the rear of the plinth. The hinges only fit one way, removing any guesswork from the process.
All told, expect to spend about 20 minutes getting the DP-500BT unpacked, assembled, and ready to spin your favorite LPs.
Tech Talk
Before getting into how the DP-500BT sounds, let’s take a closer look at its technologies, because Denon has blended several traditional turntable design choices with features intended to make vinyl easier to integrate into a modern audio system.
At its heart, the DP-500BT is a belt-drive turntable. Rather than placing the motor directly beneath the platter, Denon uses a rubber belt to transfer rotational energy from an offset motor pulley. That physical separation helps prevent motor vibrations from traveling directly into the platter, which, obviously, is something you want to avoid.
Belt-drive isn’t inherently superior to direct drive, as either approach can perform exceptionally well when properly engineered. In this case, however, it’s a logical choice for a home listening deck where isolation and low mechanical noise take priority over the rapid startup and precise speed control commonly associated with direct drive designs.
A selector on the plinth provides access to 33 1/3, 45, and 78 RPM playback. The first two speeds cover modern LPs and singles, while 78 RPM support makes it possible to explore older shellac releases. Because those records generally use wider grooves than modern vinyl, serious collectors will likely want a dedicated 78 RPM cartridge or stylus.
That’s where the DP-500BT’s removable headshell becomes especially useful. The entire cartridge assembly can be unlocked from the tonearm and exchanged in seconds, allowing an owner to keep the included cartridge ready for everyday listening while maintaining a second, properly configured headshell for shellac records. The same flexibility also creates a simple upgrade path for standard vinyl playback. Moving to an elliptical or more advanced stylus profile can reduce distortion and retrieve more detail from a record, giving owners room to expand the turntable’s performance as their interest in vinyl grows.
Once the stylus begins tracing a record’s grooves, the resulting signal needs somewhere to go, and Denon gives owners two wired pathways before Bluetooth even enters the conversation. The easiest route is the DP-500BT’s internal phono stage, which amplifies and equalizes the cartridge’s low-level output before sending it through the turntable’s RCA connections at line level. That means you can connect the DP-500BT to a receiver, integrated amplifier, or powered speakers, even if your gear doesn’t have a dedicated phono input. As mentioned in the opener, the internal stage can also be bypassed, allowing the cartridge’s raw signal to feed an external phono preamp or a component with its own phono section. Most newcomers probably won’t need that option right away, but it leaves the door open for a better phono stage down the road.
And then there’s Bluetooth, the feature that gives the DP-500BT its most distinctive capability.
Bluetooth transmission starts with SBC, a baseline lossy codec supported by virtually every Bluetooth audio product under the sun. Pair the DP-500BT with headphones or speakers that also support aptX, aptX HD, or aptX Adaptive, and the turntable will automatically negotiate the best compatible option available between the two devices. aptX and aptX HD are designed to improve on a typical SBC connection, giving compatible gear a better chance at preserving clarity, detail, and dynamic expression. aptX Adaptive adds another wrinkle by adjusting its bitrate based on wireless conditions, allowing it to favor sound quality when the connection is strong and shift toward reliability when interference or congestion starts to creep in.
The turntable’s Bluetooth indicator light provides a quick way to see which codec family is active. A blue light confirms an SBC connection, while purple indicates that aptX, aptX HD, or aptX Adaptive is being used. Unfortunately, the light doesn’t distinguish among the three aptX options, so identifying the exact codec may require checking the receiving device or its companion app.
Playback and Operational Notes
Actually playing a record on the DP-500BT is fairly straightforward, though its controls do have a few quirks. For starters, there isn’t a dedicated power button. The speed selector doubles as the power control, with positions for Off, 33 1/3, 45, and 78 RPM. Moving the dial from Off to any of the three playback speeds immediately starts the platter, even while the tonearm remains secured in its rest.
From there, playback is mostly manual. A cueing lever raises the tonearm, allowing it to be positioned over a desired track. Moving the lever back down lowers the cartridge, and the needle gently settles into its chosen groove. It's a simple feature, but an important one, especially for listeners who may not feel comfortable manually dropping a stylus onto a record.
Bluetooth operation is equally simple. A button on the front of the plinth controls pairing. Hold it down until an indicator begins flashing blue, then place the receiving headphones or speaker into pairing mode. Assuming both devices are nearby, they should connect within a matter of seconds.
During my review, I tested the DP-500BT with several wireless products, including a pair of Bowers & Wilkins Px8 S2 headphones, Denon's Home 200 wireless speakers, and a Klipsch "The Three" tabletop speaker. Every connection was quick and trouble-free. Better still, the turntable remembers the most recently connected device, eliminating the need to repeat the full pairing process before your next listening session. Simply tap the Bluetooth button, watch the indicator change from red to solid blue or purple, and you’re ready to go.
The DP-500BT’s semi-automatic operation provides another welcome layer of convenience. When the stylus reaches the runout groove at the end of a record, the turntable eventually raises the tonearm and stops the platter. The arm doesn’t return to its rest, but the stylus is lifted safely away from the record’s surface. I stress "eventually" because during testing, the stylus remained in the runout groove for roughly 17 seconds, sometimes longer, before the mechanism activated. You’ll also need to move the speed selector to Off, then back to the desired speed, to get the platter spinning for the next listening session. So, while the feature works and protects the stylus, the entire process feels a tad clunky.
During the review period, I tested both 33 1/3 and 45 RPM playback, using the included adapter for a 7" single. Both speeds appeared stable during normal listening, with no obvious pitch fluctuation or operational concerns. The turntable also does an impressive job isolating playback from outside vibration. I tapped directly on the dust cover and deliberately knocked on the surrounding furniture while records were playing. Some physical contact will inevitably find its way into playback, but the Denon did a notably good job of preventing those disturbances from becoming intrusive.
Sound Quality
For wired listening, I connected the DP-500BT’s line level output to a StormAudio ISP MK2 processor, with Emotiva amplification ultimately driving a pair of GoldenEar Triton One.R speakers. Using the turntable’s internal phono stage and included Denon DSN-85 cartridge, I was impressed by its ability to pull detail and character from several of my favorite demo albums.
Norah Jones’ Come Away with Me revealed an articulate and nicely balanced presentation. Vocals sounded clean and expressive, with enough texture to preserve the intimacy of the recording, while piano, guitar, and percussion maintained clear separation across the soundstage. High frequencies had a pleasant sense of openness, bass remained controlled and well-proportioned, and smaller details were easy to identify.
RAC’s EGO gave the DP-500BT a chance to stretch in a different direction. Its electronic textures, driving rhythms, and layered production arrived with good definition, showing that the Denon is comfortable with more than acoustic vocals and traditional instrumentation. Bass lines remained composed, synths retained their individual character, and the deck kept complex passages from collapsing into a congested whole.
Across everything from rock and vocal recordings to faster electronic material, the DP-500BT proved to be a capable and musically satisfying performer. Where the combination falls slightly short is in that final degree of vibrancy and expression that you experience with much more expensive systems. Even so, it does justice to a wide range of music and provides a convincing foundation for newcomers and buyers looking to spend less than $1,000 on a turntable.
Of course, Bluetooth is where the DP-500BT really separates itself, and its performance in this realm proved eye-opening. The Denon Home 200 stereo pairing made a particularly compelling case for the DP-500BT’s wireless capabilities. Their compact size allows them to fit comfortably into spaces where conventional systems might not fit, while the turntable eliminates the need to run analog cables across the room. Together, they created an unusually simple vinyl system that was easy to set up, easy to operate, and far more capable than its footprint might suggest.
Playing Norah Jones’ Come Away with Me, I heard much of the same balance, detail, and musical character that came through during wired listening. Jones’ voice retained its warmth and intimacy, while subtle instrumental textures and smaller background details remained easy to hear. Nothing about the presentation struck me as objectionable or overtly compromised, and had I not known the connection was wireless, I might easily have believed I was listening through a wired system.
Signal stability was equally impressive. I didn’t encounter dropouts, pops, or interruptions while listening through the Home 200s. The connection remained steady from beginning to end, allowing the technology to fade into the background and the music to take over. Klipsch's The Three delivered similar trouble-free operation, reinforcing just how easily the DP-500BT can move between different wireless systems.
As good as the speakers sounded, the Px8 S2 headphones produced the most surprising experience. Sound quality was excellent, the connection remained stable as I moved throughout my home, and the freedom of listening to a record on the go quickly became one of the DP-500BT’s most appealing features. But the biggest surprise arrived when I compared several songs played on vinyl with the same tracks streamed through Spotify. This wasn’t a controlled, level-matched comparison, but the result consistently favored the records. Through the DP-500BT, music sounded slightly warmer and more rounded, with greater body and a more expressive overall presentation. Spotify often sounded comparatively flatter and thinner.
I wasn’t expecting that kind of outcome. In fact, I assumed Spotify would produce the cleaner and more convincing Bluetooth experience, while digitizing the output of a record would put the turntable at a disadvantage. Instead, the character of the vinyl pressing remained readily apparent – super cool.
Conclusion
Denon gives you a lot with the DP-500BT. Its internal phono stage makes it easy for newcomers to add vinyl to nearly any system, while the removable headshell, replaceable cartridge, and bypassable phono stage leave plenty of room to chase higher levels of performance as an owner’s interest and budget grow. That alone makes it a capable and flexible turntable, but Bluetooth is the feature that truly sets it apart. Whether sending records to a wireless speaker across the house or pairing with headphones for private listening while moving freely from room to room, the DP-500BT brings some of the convenience we associate with streaming to a format that has traditionally kept listeners tethered to one system. Better still, it does so without draining vinyl of the warmth, detail, and character that make it such an enjoyable format.
Color me surprised, but I really like this one, especially when wires don’t come into play.
Buying Options
- Click Here to Buy Denon's DP-500BT through Amazon: https://amzn.to/4wjT1oJ
- Click Here to Buy Denon's DP-500BT through Audio Advice: https://audioadvice.io/3RSi8jl
Denon DP-500BT Hi-Fi Turntable with Bluetooth Specifications
Drive System
- Motor: DC
- Drive Type: Belt-Drive
- Operation: Semi-Automatic
- Auto Tonearm Lift: Yes (at end of playback)
- Speeds: 33⅓, 45, 78 RPM
- Wow & Flutter: 0.08% (WRMS)
- Tonearm: S-Type
- Cartridge Type: Moving Magnet (MM)
- Stylus: CN-6518
- Universal Headshell: Yes
- Rated Output: 2.5 mV / 1 kHz
- Frequency Response: 20 Hz to 20 kHz
- Signal-to-Noise Ratio: 65 dB
- Built-In Phono EQ: Yes, switchable
- Phono EQ Output: 150 mV / 1 kHz
- Phono EQ Frequency Response: 20 Hz to 20 kHz
- USB Direct Recording: MP3 (192 kbps), WAV (44.1 kHz / 16-bit)
- Bluetooth Codecs: SBC, aptX, aptX HD, aptX Adaptive
- Audio Outputs: RCA
- Dust Cover: Removable
- Finish: Black
- Dimensions (W × D × H): 16.7 × 14.4 × 4.65" (425 × 367 × 118 mm)
- Weight: 13.2 lbs (6 kg)
- Power Supply: AC 100–240V, 50/60 Hz
- Carton Dimensions (W × D × H): 19.6 × 16.7 × 9.06" (500 × 425 × 230 mm)
- Carton Weight: 17.6 lbs (8 kg)
