complete Newbie needs lots of help
Kenneth Ostergaard
Primare 201- Minidsp 4 x 10 - Yamaha Musiccast
Primare 202 x 2
Sansui B2101
Hypex Ncore 400 x 2
Primare 204 Goldtop
JBL 2404H x 2 - JBL 2425H x 2 - JBL 2206H x 2
JBL 2206H x 2
hello Everyone
Recently I purchased a minidsp 4 x 10 with the umik 1 microphone.
this is my stereo speaker setup
big sub centerbox with 2 x jbl 2206H in a portet cabinet
side system 1, jbl 2206H in closed cabinet
side system 2, jbl 2404H and 2425H
the subs are connected to Sansui B2101
mids to Primare 202 x 2
top to Hypex Ncore 400
controle amp is Primare 201
music source is Tidal through Yamaha Musiccast or Primare 204 goldtop
Am I correct in measuring the subs as one unit?
At what frequency ranges should the different boxes be meassured at?
so far I tried subs from 10-100hz
mids from 80-2000hz
tops from 2000-20000hz
If someone has advice to how the xover should be configured that would be nice too, especially hi and lo pass filters but also where to cut between the boxes?
what kind of smoothing should I use for my graphs?
thanks in advance
Kenneth
Wayne A. Pflughaupt
Corpus Christi, TX
Canton Karat 920
Canton Karat 920
Canton Plus D
Hsu ULS-15 MKII
Stock Yamaha Remote
Roku Express
You should probably find an on-line forum for DIY pro audio speaker systems. It’s highly doubtful that any hi-fi DIY speaker enthusiasts will have a clue about a system like this.
REW graphs for low frequencies (< 200Hz) are best viewed with no smoothing. Full range graphs are best viewed with 1/6- or 1/3-octave smoothing.
Kenneth Ostergaard
Primare 202 x 2
Sansui B2101
Hypex Ncore 400 x 2
Primare 204 Goldtop
JBL 2206H x 2
Thanks Wayne
already read a lot and I am wiser now.
My system is not a pro audio system, at least I dont think so. It is a home stereo setup meant for quality listening.
Regards
Kenneth
Wayne A. Pflughaupt
Corpus Christi, TX
Canton Karat 920
Canton Karat 920
Canton Plus D
Hsu ULS-15 MKII
Stock Yamaha Remote
Roku Express
The end use matters little; those are pro-audio drivers commonly found in many JBL commercial / PA speakers, and it’s not typical in a hi fi system to have the drivers in their own separate cabinets (aside from the subwoofer). Not that that’s a bad thing; one of the best-sounding custom pro audio speaker systems I ever heard used JBL drivers.
The point is that few, if any, in the DIY hi-fi community will be able to assist you in setting up a system like yours. If you can’t find a DIY forum for pro audio enthusiasts, then I’m sure JBL tech support can help you with crossover settings (not sure what you’re using for that; didn’t see anything suitable in your equipment list).
Once you get that ironed out, you can do full-range REW measurements to help set the relative levels between the drivers.
Kenneth Ostergaard
Primare 202 x 2
Sansui B2101
Hypex Ncore 400 x 2
Primare 204 Goldtop
JBL 2206H x 2
Hi Wayne
Thanks for your advice and info:-)
I am using the minidsp 4x10 hd for the xover.
I also have a dbx driverack pa2. Not sure yet which one I will use in the end.
Regards
Kenneth
