Hi,
I've got a rme multiface2 with ada8000 connected to it and using behringer ecm8000 mic.
Using REW(stable version 5.19) on linux.
When calibrate the 'help' says it should be fairly flat.
Well, here it's far from flat.
No id what i'm doing wrong.
One output(reference output) is connected to input as feedback input.
One input is setted to input of the mic
When 1khz tone is played it set my levels pretty same(less then -1db difference).
But when the sweep is played, the mic is clipping to i have to set the input level bit lower on the feel, but headroom was like -14db so
not that big difference from -12db.
This is result.
any idea what's going on?
Thank you
This is result.
Thank you
